c 60 with CUCM 7.1.5
Yasir Vistro
Dear All
i have C 60 with software version 5.1.4  and CUCM  7.1.5 .  i like to register it as 3rd party SIP device (advance and basic) . but unable to register it . kindly help.  kindly share the Document .  thanks
Yasir Vistro
Yasir Vistro
2 Accepted Solutions
Rafal Szeremeta
Hey Yasir
Can you upgrade yours CUCM to 8.6? That would be the easiest solution as after you can add C60 as native sip device.
Rafal
Hi Yasir,
You can get the document on the following link :
https://supportforums.cisco.com/docs/DOC-26382
Hope this helps,
Mubashshir Akhtar
Thanks Mubashshir Akhtar
9 Replies 9
Rafal Szeremeta
Hey Yasir
Rafal
Rafal
customer don't want to upgrade .   kindly provide  the solution  for the Current scenerio. thanks
Yasir Vistro
Yasir Vistro
HI Yasir,
as Rafal already mentioned and as it\s also clearly stated in the TC5.1.4 rekease notes :
From TC5.0.0 the C/EX/MX-Series supports provisioning and basic call functionality with Cisco Unified Communications Manager (CUCM) version 8.6 and above
Unless the customer it's not willing to perform this CUCM upgrade they will have to consider a redesign of the current setup and bring into the picture a VCS device that can bridge the gap between C series devices and CUCM 7.1.5
Hi Yasir,
check out this thread.
it should help you to configure the c-series as third party.
Also if you search the forum for such type of issues you will find lots of posts.
Thnx
Alok
Hi Yasir,
Hope this helps,
Mubashshir Akhtar
Hi, Mubashshir.
We are using End User from LDAP, and I can't register C60 on CUCM. Is it possible register C60 with LDAP End User?
Hi Andrei,
What is the CUCM version? in the CUCM once you enable the LDAP search the local user option get disabled.
As CUCM doesn't sync the passwords for AD users. I believe for the digest user authentication  you need to manually set the password for the digest user in CUCM.
I have to test this in the lab to make sure with newer CUCM version.
One more thing did you configured CUCM  to verify the end user passwords with the LDAP?
Rgds,
Alok
Hi, Alok.
Thank you for your answer.
CUCM version is 7.1.5.32900, C60 version is TC5.1.4.295090. I've tried to change Digest Credentials for my C60 end user (vcs-c60) in CUCM EndUserConfiguration. Unfortunately, with no positive result. For information, LifeSize Desktop has registered on CUCM with this username and without password, C60 can't.
Yes, Use LDAP Authentication for End Users has been selected.
Andrei Atamanenko from IPad.
Yasir Vistro
Thanks  all
Appreciate your support
Yasir Vistro
Yasir Vistro
