C-Series dual usage of RC and TouchPanel
Hi there,
normally the RC would be set out of function, if I register a TouchPanel to (f.ex.) a C60 codec.
Is there any possibility that allows to use the Remote Controller at the same time?
Maybe with a hidden xconf or xcom command?
(SW Vers. TC5.1.0)
Many thanks in advance!
Fabian
Dharmesh Nandoria
Hi Fabian,
There is no hidden commnad to activate both at same time,
kind regards,
Dharmmesh
Thank you both - Dharmmesh and Mubashshir
mubakhta
Level 4
Level 4
Hi Fabian,
I am afraid that would not be possible. By design, the Touch Panel takes the full control of the OSD. If you wish to use the remote controller, the only way is to disconnect the Touch Panel. There is no hidden command to disable this behavior.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
