C Series registration to 2 GK
ginowrief
Is it possible to register codecs (C series) with 2 different Gatekeeper?
Thx in advance
Martin Koch
If its for a failover you could use SRV records, but its still only one active at a time
and if its 2 different ones I would also not really recomend that. Also the address would
need to be the same.
So in short: No, thats not possible.
I think the e20 was the only device supporting different sip registrars at the same time,
but thats neither your device, nor the protocol you ask for :-)
If you just want to receive a call, maybe its possible to register it to one and make a
transform/search rule or use findme to map it to the other gk.
Jens Didriksen
Level 9
Level 9
As Martin said, no, you cannot register with multiple h.323 GKs.
You can, however, register C-series to a maximum of 4 different SIP registrars.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
