C20 AEC
suporte
Hello, I`d like to know if the C20 Videoconferencing System has the option to enable Echo Cancellation on the line input.
Thank you.
Joe Vallender
Level 3
Level 3
Software version might be helpful.
Have you looked at the xconfig commands:
xConfiguration Audio EcReferenceDelay Mode
Set the acoustic echo cancellation reference delay mode.
Requires user role: ADMIN
Value space: <Off/Fixed>
Off: No extra latency will be added to reference signal used by the acoustic echo canceller.
Fixed: The extra latency given by Audio EcReferenceDelay Delay will be used to compensate for
latency in the acoustic path, typically introduced by TV monitors.
Example: xConfiguration Audio EcReferenceDelay Mode: Off
xConfiguration Audio EcReferenceDelay Delay
Adjust the time slot (in milliseconds) of the acoustic echo cancellation. Only applicable when Audio
EcReferenceDelay Mode is set to Fixed.
Value space: <0..250>
Range: Value from 0 to 250 milliseconds.
Example: xConfiguration Audio EcReferenceDelay Delay: 120
Patrick Sparkman
Echo cancellation only applies to microphone inputs, does not apply to line inputs.
