12-07-2012 05:33 PM - edited 03-18-2019 12:15 AM
Can i use the same cable from C20 Camera on the SX20 Camera?
Leonardo Santana
Solved! Go to Solution.
12-07-2012 08:06 PM
Hello Leonardo
SX 20 and C series use different connections for the cameras, so that is not possible using supplied cable.
Please check this link:
Thank you
Rafal
12-08-2012 07:53 PM
Hey Leonardo,
Yes the hdmi cable for the TV/Monitors are the same for each codec. The SX20 supports the Visca protocol which is why the camera cable is different. I however have connected a regular HDMI cable between the camera and codec without any issues as far as I can see, but always keep in mind to follow the guides and use the recommended cables.
Adam
12-07-2012 08:06 PM
Hello Leonardo
Thank you
Rafal
12-08-2012 07:31 PM
Ok Thanks
And the hdmi cable that connects on tv is the same for C20 and SX20 correct?
Leonardo Santana
12-08-2012 07:53 PM
Hey Leonardo,
Adam
12-09-2012 06:56 AM
Thanks Adam
I ll follow the Cisco recomendations.
Leonardo Santana
