C20 TMS Provisioning templates.
Where do i get them?
Searched through downloads, in TMS section and QuickSet section with no success.
2 Accepted Solutions
gubadman
Level 3
Level 3
C Series endpoints aren't provisioned like EX or MX.
They can be added to TMS in the Navigator section and configured from there instead.
Guy
Correct what Guy says, C Series EPs do not support TMSPE type provisioning. See the TMSPE Deployment doc for what EP systmes are currently supported using TMSPE:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
And as Guy says, they can be added to TMS in the Systems > Navigator and then configured using TMS's configuration templates, i.e. Systems > Configuration Templates
5 Replies 5
gubadman
Level 3
Level 3
Guy
Thanks, guys.
Kjetil posted a unsupported solution in another thread to make Provisioning work for C20, which sounds interesting:
https://supportforums.cisco.com/thread/2191224
Regards, Paul
Hi Paul,
I've just made a comment on the thread you reference above. What Kjetil says my be possible but until the SX and C-Series folks provide an "official" schematic for these type of EPs so has to provision them with the TMSPE solution, then it won't be "officially" supported by the Cisco support services.
At the end of the day, anything is possible but tread carefully when wading into unsupported solutions
rgds,
Dale
