C40 license key and traversal
mfouad.jahmi
hi all,
im wondering on C40 integrator package as i have seen this option key :
LIC-INTP-C40-DD --------> Integrator Package C40 Dual Display Option
is that really necessary required when you only have oen monitor ?
what is the use of that option above !!! activating dual monitor ??!!!!!!!
secondly, is it really working when you assign public ip address using NAT agianst the C40  ??
please guys let me know what are your comments
vivsing2
Hi Mohamad,
As per DD option is benefitial for two monitor display, it will have no effect on single screen system.
This option will activate both Video output, so that they can show different display on both screen, such as when on call with single participant and they are sharing presentation, then on first screen you will get far end and on second screen you will get presentation.
C40 NAT is useful to enable NAT on H323 Payload, it have nothing to do IP Packet NAT.
Vivek
