03-10-2014 09:53 AM - edited 03-18-2019 02:42 AM
Hello All,
I have 2 Cisco c40 units. 1 of the units changes the SerialPort LoginRequired setting to "on" by itself. It is running software version TC6.2.0.20b1616.
The other unit is running TC 6.1.1.7d7af15 and is having no issues.
I need the serial port login to stay off because I am controlling it from a 3rd party touchpanel control system.
Does anyone have any knowledge of this issue and how to resolve it?
03-10-2014 11:07 AM
serial port login required setting should not change by itself.
is this happens after reboot of this unit ? are you provisioning this unit with either TMS or CUCM ?
03-11-2014 02:38 PM
From what I've been told by the end user, it is changing without a reboot. It is provisioned with CUCM.
03-14-2014 02:47 PM
Both C40's have been upgraded to TC7.0.2.aecf2d9. The serial settings are set a loginrequired "OFF". After reboot the settings is "ON".
06-05-2015 05:46 AM
i am also having this issue, C40 registered to UCM, upgraded from TC6
first i upgraded to 7.3.2 but saw issues where options would not change even though i had clicked save, now i have downgraded to 7.2.1 and have issue where if i set serialport login required to off and reboot it defaults to on.
did you find a resolution?
06-05-2015 05:57 AM
i have just found what the problem was. there is a setting for the serial port on the device page in UCM, set that to off, now all good!
10-02-2015 07:35 AM
