C90 + TC Console
Hello, team!
I have troubles with connecting to C90 with TC Console.
When I trying to do this it show error window with"Could not connect to 192.168.60.13" message.
Software version: TCNC4.2.1.265253
TC Console version: 3.3
OK
xconfiguration SystemUnit name
*c xConfiguration SystemUnit Name: "C90"
** end
OK
xconfiguration NetworkServices
*c xConfiguration NetworkServices Telnet Mode: On
*c xConfiguration NetworkServices SSH Mode: Off
*c xConfiguration NetworkServices SSH AllowPublicKey: On
*c xConfiguration NetworkServices HTTP Mode: On
*c xConfiguration NetworkServices SNMP Mode: ReadWrite
*c xConfiguration NetworkServices SNMP CommunityName: "public"
*c xConfiguration NetworkServices SNMP SystemContact: ""
*c xConfiguration NetworkServices SNMP SystemLocation: ""
*c xConfiguration NetworkServices SNMP Host 1 Address: ""
*c xConfiguration NetworkServices SNMP Host 2 Address: ""
*c xConfiguration NetworkServices SNMP Host 3 Address: ""
*c xConfiguration NetworkServices H323 Mode: On
*c xConfiguration NetworkServices SIP Mode: On
*c xConfiguration NetworkServices NTP Mode: Auto
*c xConfiguration NetworkServices NTP Address: "1.ntp.tandberg.com"
*c xConfiguration NetworkServices MultiWay Address: ""
*c xConfiguration NetworkServices MultiWay Protocol: Auto
** end
May be you can help me?
Be ready
23 Replies 23
vivsing2
Beginner
Beginner
Hi Valeriy,
The TC-Console can be used to configure audio and video layouts for the CTS C40 (audio only), CTS C60 and C90. The TC-Console requires the codecs to run TC4 or later.
So i don't think it will work for TCNC software
here is guide:
http://www.tandberg.com/collateral/documentation/User_Manuals/Cisco%20TelePresence%20System%20TC-Console%20(TC4.0).pdf
Vivek
In the TC console release notes for TC console software version 3.1, telnet and TCNC support has been added.
So, if it doesn't work now with version 3.3, it should be broken somewhere somehow.
Checking with developer where could have gone wrong, will update if there is any further info.
Hi, Teck, Vivek
Thanks for information.
Do you have link to 3.1?
Be ready
Thanks, Vivek.
But it's only 3.3. available via your link...
Be ready
Please see attached for version 3.1.   Please unzip the file, goto Data folder, look for launch.jnlp and double click this.  Then version 3.1 should launch.
If you have a newer version for example 3.2 that was run previously, you might need to goto control panel>java>temporary internet files>view , and delete any TC console you see there.
If you are using version 3.1, do take note:
a) It will not work with TCNC5.x
b) I tested with TCNC4.1, it works, TCNC 4.2.x should work also, but I never have time to test it.
c) you will see the same layout as what you see in the TC console document instead of those you see in TC console version 3.3
Please try it
Hi, Teck.
Same error.
If it can help you, I attach .pcap file with conversation.
Use filter ip.addr == 192.168.60.13
Be ready
same error meaning cannot connect to the codec?
You can launch the TC console version 3.1 right?
Did you try with TCNC4.1?
Q: same error meaning cannot connect to the codec?
A: yes
Q:You can launch the TC console version 3.1 right?
A: Yes
Q:Did you try with TCNC4.1?
A: download in process :-)
Be ready
For all  4.1.0,4.1.1,4.1.2 same error.
Screenshot attached
Be ready
Teck Chye Tang
Is http turn on?
Is http turn on?
Yes
Be ready
Hi guys,
Link to developer.tandberg.com has been broken.
Could anybody to attach here latest version of TC Console. And version 3.1 does not work with my win7
Thanks in advance,
Hi Ruslan,
try the link below
http://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
let me know if that helps
Ravi Kr
Recognize Your Peers
