Hi all,
I'm having some issues getting a call 384k bonding from CMS out via a Cisco 8231 gateway the current setup is;
CMS -> Expressway -> gateway.
I have proved the call a H323 registered endpoint on the Expressway - unfortunately I haven't been able to test a SIP registered endpoint at the moment. But when I attempt a call from a CMS space because of the delay from the gateway the CMS send a SIP cancel 40 seconds after the invite which drops the call;
2021-06-22 15:44:02.603 Info call 25: ending; local SIP teardown with reason 32 (timeout - provisional responses) - not connected after 0:40
I've been checking the documentation to see if this is a value I can adjust but my searches so far have been fruitless.
Can anyone offer some advise please?
Software versions;
CMS 3.2
Expressway 14.0
GW 2.2
Many thanks,
