04-11-2012 06:38 PM - edited 03-17-2019 11:02 PM
Hi Guys,
I encountered a problem that when CTS call to Telepresence Server, the call got dropped once a while.
This happens after turn on the CTS encryption.
Is there any extra setting to make it stable?
FYI.
CTS ver 1.90
TS ver 2.2(1.43)
CUCM ver 8.6.1
VCS ver x7.0.3
Thanks.
04-11-2012 06:59 PM
as per my kowledge there was one limitation on Tandberg software version, please let me know software version of Tandberg endpoint.
Vivek
04-11-2012 07:01 PM
Hi Vivek,
Telepresence Server is on 2.2(1.43).
Actually the call is from CTS (ver 1.9.0) to Telepresense Server.
Thanks.
04-11-2012 07:12 PM
I got your point; however it seems that call fail while negotiation, so might be Tandberg endpoint is not at required software version, if you will let me know then i can check whether there is no issue with software version, then we can move forward to solve issue.
Vivek
04-11-2012 07:14 PM
Hi Vivek,
Thanks a lot.
Tandberg endpoint is runnning on TC5.1
04-12-2012 03:08 AM
Then i think we need to get log, Let me know, are you facing this issue when initiating call from Tandberg endpoint as well.
I am looking log from Tandberg Endpoint.
