Calls from JabberTablet (via VCS) to Internet Endpoints (SIP) KO!
I have  an issue with JabberTablet for Ipad.
The calls between  JabberTablet and JabberTablet are  OK,
The calls between  JabberTablet and Jabber Video are  OK,
The calls from  JabberTablet  to any public IP is KO!
I use a perfectly working video infrastrastructure:
VCS Control X 7.2
VCS Expressway X 7.2
TMS 13.2.1
All calls to public internet endpoints from Jabber Video are working  perfectly.
When I  look into the VCS Ex for see  what’s wrong,  I found that for every  call from JabberTablet to any public IP  have this format
Public_ip@my_sip_domain.com
In this way my Expressway  doesn’t search the destination endpoint on the public internet.. if I do the same call with the same user from JabberVideo, the call will be connected!
note all calls from Ipad are done from 3G connection with public IP
Does you  have found the same behaviors?  Or does you have any suggestions  ?
Carlo
awinter2
Rising star
Rising star
Carlo,
instead of calling the IP address alone, try inserting a dummy alias in front of the IP address, so that if you want to call 213.80.80.80, enter 'test@213.80.80.80' or something similar on your Jabber iPad client.
- Andreas
Here a  search on my vcs ex for a call from user1 (ipad) to a internet  endpoint 213.80.80.80
Search (393)
State: Completed
Found: False
Reason: Proxy Authentication Required
Type: SIP (INVITE)
CallSerial Number: 1dc65064-0ef7-11e2-b124-0010f31f193e
Tag: 1dc65208-0ef7-11e2-99d3-0010f31f193e
Source (1)
Authenticated: False
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Value: user1.jabbertablet@my-sip-domain.com
Zone (1)
Type: Default
Path (1)
Hop (1)
Address: 172.16.52.119:49671
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Value: sip:213.80.80.80@my-sip-domain.com
StartTime: 2012-10-05 16:15:29
Duration: 0.04
SubSearch (1)
Type: Transforms
Action: Not Transformed
ResultAlias (1)
Type: Url
Origin: Unknown
Value: 213.80.80.80@my-sip-domain.com
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Name: Local zone – no domain
Zone (1)
Type: Local
Protocol: SIP
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Address: 199.99.99.99:0
Alias (1)
Type: H323Id
Origin: Unknown
Value: 213.80.80.80
Zone (2)
Type: Local
Protocol: H323
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Alias (1)
Type: H323Id
Origin: Unknown
Value: 213.80.80.80
SearchRule (2)
Name: Local zone – full URI
Zone (1)
Type: Local
Protocol: SIP
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Type: Local
Protocol: H323
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
SearchRule (3)
Name: Traversal zone search rule
Zone (1)
Type: TraversalServer
Protocol: SIP
Found: False
Duration: 0.01
Gatekeeper (1)
Address: 217.19.158.98:31159
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Protocol: H323
Found: False
Reason: Not registered - Destination not found
Duration: 0.01
Gatekeeper (1)
Address: 217.19.158.98:49904
Alias (1)
Type: Url
Origin: Unknown
awinter2
Rising star
Rising star
Carlo,
- Andreas
Hi Andreas, with
test@213.80.80.80 work fine.
but how isn't possible to call only the public ip ??
thanks,
Carlo
Carlo,
this simply means that the client behavior when calling IP addresses has been implemented slightly different on the Jabber iPad client compared to the Jabber Video client for Windows and Mac.
- Andreas
Recognize Your Peers
