Cannot access WebUI after upgrade 14.3.1 from 12.7.1 expressway edge
5959
Hi Guys, I Upgrade my expressway edge to x14.3.1 from x12.7.1(workin on Esxi 5.5 )
I can access CLI well, and When I access to CLI after upgrade there are several line
3 alarms:
* error Application failed - Several unexpected software errors were detected in /apache2/bin/httpd -f /etc/apache2/httpd.conf -DNO_DETACH -DHTTP -DSSL: 1. This service will not be restarted automatically.
* warning Security alert - SSH tunnels protocol violation. Access to Expressway is blocked for new IP addresses - x.x.x.x
* warning Configuration warning - For phone book requests to work correctly, authentication policy must be enabled on the Default Subzone and any other relevant subzone; authentication must also be enabled on the Default Zone if the endpoints are not registered
Before I upgrade the system I can access well on browser (firefox )by IP https:x.x.x.x:445
But I cannot access after upgrade (I tried various browser firefox, chrome, edge ...)
when I check by cli all xconfigurtion it seems nomal
*c xConfiguration Administration HTTP Mode: On
*c xConfiguration Administration HTTPS Mode: On
so I reboot 2 times and changed the port number from 445 to 8080
but Issue is steel facing me
Does anyone know about this issue?
Please help me
b.winter
Not related to your problem, but I hope you upgraded the ESXi version too. Expressway X14 is no supported on ESXi 5.5.
b.winter
What could be related to your problem:
In the versions X14 there is a new feature called "dedicated management interface (DMI)", which wasn't there in X12.
Maybe now, after the upgrade this new interface was activated and now you need to deactivate it.
Hi B
I tried to disable DMI but the issue is steel facing me
xcommand Networkinterface DedicatedManagementInterface: disable
time_emitted | result
11 ms | OK
My customer does not want to upgrade the hypervisor, so this is to difficult lab
Thanks for your metion
