Cant find ACME configuration on the Expressway
just upgraded the VCS Expressway from 8.10.2 to 12.5.7. This should give me the chance to use ACME for certificate management, but going to Maintenance - Security - Server certificate, there's no configuration for ACME to be found anywhere.
Just the usual Certificate data, CSR and Upload..
Anyone else experienced this or have a solution??
Going to https://<expr.adress/api/management/configuration/acmeproviders/ i get this:
[{"peer":"127.0.0.1","local_peer":true,"num_recs":1,"records":[{"uuid":"fe71ae97-a951-4899-bd63-83617b922f65","name":"Let's Encrypt","url":"https://acme-v02.api.letsencrypt.org/directory","email":"","terms_of_service":"RequiresAcceptance","terms_of_service_url":"https://letsencrypt.org/repository/","last_tos_check_time":0,"default":true}]}]
From the look of the screen shot that is from a VCS, not an Expressway. This is how it looks on the MRA Expressway E node where we test and verify this function.
Response Signature
6 Replies 6
The response looks correct. It has the v2 listed. Are you checking this on your E node? It would only be available on that.
Response Signature
Thanks, and yes I am.
It's a VM running on VMware 6.5 but I don't think that should be a problem, right?
No that’s not a problem. We have the same setup and it works. Can you please take a screenshot of the server certificate page and post here?
Response Signature
Japp, like this?
Response Signature
So there's a cisco expressway and a vcs expressway.. which pretty much does the same thing. That's just awesome. How can anyone not love Cisco (irony).
