ā01-07-2013 01:28 AM - edited ā03-18-2019 12:23 AM
I am looking for Cart / Cabinet for Cisco Video Conference SX20
Any suggestion / recommendationn?
Mohamed
ā01-07-2013 01:36 AM
Hi Mohammed.
I would recommend you to get the SX quick set box with a wallmount. It will be mountable almost anywhere.
When it comes to recommendations on carts/cabinet, then I would recommend you to sit down and decide what kind of screen you want to use, how mobile you would like it to be - and so on.
If you need a system with a stand I would recommend you to have a look at MX300 / MX200 options from cisco.
http://www.cisco.com/en/US/products/ps11776/index.html
You can also buy a MX200/MX300 with a table stand and then buy a table to move around.
//Marius
ā01-07-2013 02:12 AM
Hi Marius,
Thanks for your reply
SX20 is already exist in my customer site
They are looking for mobile / portable cart that can be move from one room to another
Screen is LCD 46"
Mohamed
ā01-07-2013 06:28 AM
Hi Mohamed.
Cisco does not provide a cart for the SX20 as far as i know.
I would recommend you to have a chat with your partner/cisco sales person, and see if you can fit the MX200/300 cart to SX20 and a 46 inch screen.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11304/ps11314/ps11462/data_sheet_c78-708753.html
//Marius
ā01-07-2013 12:59 PM
Hi Mohamed
We use for your purpose AV Solutions from CHIEF:
http://www.chiefmfg.com/VideoConferencing
Br Oleksandr
