change firmware on 8945 from sccp to sip
delucama-BIS
 how can i change the firmware on a 8945 from sccp to sip? I only have the cme 8.6 and the 8945 are not compatible, so i can not give them the load command for the new firmware.
is there any other possibility to change the firmware?
maybe there is a trick to get the 8945 running on the cme 8.6 ?? :-)
Thank You
Manish Gogna
See if the following helps
http://www.adrianandgenese.com/blogger/2011/02/16/how-to-upgrade-or-convert-a-cisco-ip-79xx-7940-7960-794x-796x-797x-phone-to-sip-or-sccp/
Also, the only option to use a 89xx with cme 8.6 would be as a third party sip endpoint as explined here
https://communities.cisco.com/message/132082
Manish
Thank you for your help.
I´ll try this and report!
