change guest name on webbridge
nicanor00
I have cms 3.0
When guest login on the webbridge (join a meeting), it join by default with "Guest" name (as show in the picture)
Is it possible to force user to change the default guest name before join the meeting ?
Please advise
5 Replies 5
Sadav Ansari
Click on pencil  bar right side of guest1 then you can edit name here as you want.
Please rate if its “Helpful”. If this answered your question pls click “Accept as Solution”.
Did you tried to change it using the edit option next to the name ?
Response Signature
Hello and thanks for your answer
I now that we can click edit and change the name
But some user doesnt click on edit and connect with guest name
How can I do to made the change guest name mandatory
So if you dont change the default guest name, you cannot connect on the webbridge ?
I can see a parameter  nameLabelOverride on CMS api refer guide. I never tried this. Not sure if this helps you.
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-3-0/Cisco-Meeting-Server-API-Reference-Guide-3-0.pdf
I will be upgrading a CMS to 3.X after two week , if I get a chance to test it I will let you know.
Response Signature
PavelHaurylau
You can update cms to version 3.1 or higher.
In this version user must type his name before connect to conference.
