Change Room Kit Pro Audio Output
Leonardo Santana
I need to change the audio output of my Room Kit PRO to some audio amplifiers connected at HDM1 how can i do it?
Leonardo Santana
*** Rate All Helpful Responses***
login  to Web GUI of your Room Kit PRO , then access  to Audio Console, and you can modify the audio output path as you want.
