04-08-2013 03:15 PM - edited 03-18-2019 12:54 AM
I have a camera CX20 and it give me a bad photo and i need to check , the problem?.please help
Merci
Solved! Go to Solution.
04-08-2013 03:20 PM
i had the same issue , to show for your customer that the error from the Cam , kindly connect the cam directly to your LCD and if you find the same bad phot , so the problem from the cam other you have some thing in your configuration like codec or something
thank you
04-08-2013 03:20 PM
thank you
