Cisco CMS Ldap sync successful but no spaces appear
Jigar Shah
We have Cisco CMS 2.8 and integrated with Ldap successfully; however we are not able to see any spaces created.
Anurag Srivastava1
Hello Jigar,
Are you able to see the users?
If not then check the filter again if it is correct or not also the event logs if you are getting any error.
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
Anurag Srivastava1
Hello Jigar,
Hi Anurag,
The issue was with filter.
