Cisco DX650 CUCM registeration
Karan Kapoor
I'm facing an issue of Cisco DX 650 registertion with cucm 8.6
Please suggest
15 Replies 15
Saurabh Gupta
Level 3
Level 3
Hi Karan,
What is the error message you get ? Could you pull the RTMT logs and share ?
Cisco recommends to register DX 650 with UCM 9.0 .
It would also come more powerful with upcoming UCM 10.0.
Saurabh
aborodai
Hi Karan,
Have you upload fresh .cop file to your CUCM?
I recommend you to raise TAC case instead of posting logs here.
Best Regards,
Artem Borodai
Hi Artem
yes that would be good. BTW i already uploaded the .cop file and still its not working.
Karan Kapoor
Marius Nedregaard
What are you trying to register the DX as?
//Marius
Lamar Demby
I may be way off here, but does the phone have a DN associated?  At least with my nubie experiences with SIP phones, they do not register properly until I associate a DN.
Hi Lamar
Yes i associate 1 DN to it
Karan
Karan Kapoor
It's working now
Karan Kapoor
Is there a COP file that contains the DX650 and Jabber for iPad or will I need two separate COP files?
Thanks in advance...
Karan,
What did you do to fix the issue? I have the same phone with the same issue.
CUCM 9.1(1)
COP file loaded
TFTP restarted
DN assigned
"Phone Features Unavailable"
thanks
Steven
Steven
In order to resolve this issue first you need to upload the cop file then you have to restart the entire system ( CUCM) also cluster if you have. Once its restarted the phone will be registered.
As this is the new cop file and new system restart is must. try this and let me if you face any issue but it should be resolve.
karan
Karan,
The reboot was the missing piece by me. Thank you for your help.
Steven
Steven
Great
caimanhuang
CUCM:8.6.1.10000-43
http://www.cisco.com/en/US/docs/voice_ip_comm/cdce/dx600/rel_notes/10_0_1/DX60_BK_REDB6417_00_release-notes-for-cisco-desktop_chapter_00.html
As described:
CUCM-8.6(2) use devicepack cmterm-devicepack8.6.2.xxxxx.cop
CMCM-8.5(1) use devicepack cmterm-devicepack8.5.1.xxxxx.cop
If do not upgrade the CUCM, How to support Dx650?
Thanks.
Hi Chao
You can download 8.6.1 device pack from cisco.com and try with that. It should work if now i'm worried you have to upgrade it to 6.6.2
