Cisco Endpoint change Default Call Bandwith after Save changes with CUCM
Dear Community,
I Have a Collaboration System with endpoints SX10 and SX20 registered into CUCM 10.5.
The default Call from all endpoints is 768kbps from configuration>conference1>default call,
But when I make any changes from CUCM into Endpoint ( Change Name room, etc.) the endpoint return with the default call rate (6000).
How fix this problem?
Kind Regards!!
Patrick Sparkman
This is by design when the endpoint is managed by CUCM, the default call rate will be 6000kbps on the endpoint, but when you make a call, CUCM will manage the call rate by what you have configured for the location and region settings instead of the endpoint. There is an old thread on this as well, suggest you take a look: telepresence-endpoints-call-rate-explanation-needed
