Cisco Favorties Phonebook
danny.yeomans
Good Morning All,
Is there a way to export the Favorites Phonebook from a Cisco MX300 and then re-upload to another MX300. I`m thinking this can be done via xConfiguration over the CLI but have yet to find any documentation on it. We have TMS currently delivering the phonebook to our endpoints but it is EOL and End of Support so we are wanting to turn it off. I have created a phonebook and nested folders on a Cisco Endpoint but would like to export the phonebook and re-upload it to another to prevent me going to every endpoints WebGUI and adding the entries.
Is this acheiveable?
Danny
Wayne DeNardi
If you log on to the web interface of the codec, then go to either the Configuration > Local Contacts Management, or Setup > Favorites menu option (depending on which software version you're running), you should see Import and Export buttons:
The Export button will allow you to export off the current favorites list as an XML file which you can then Import on another endpoint.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
