Adding call trace logs, i see some Bonding problems... can't really understand what is generating this issue:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.12.18 14:46:32 =~=~=~=~=~=~=~=~=~=~=~=
systemtools calltrace on
Log context 'BONDING' set to debug level 2
Log context 'H221' set to debug level 1
Log context 'H242' set to debug level 1
Log context 'H320Call' set to debug level 1
Log context 'H320Crypto' set to debug level 2
Log context 'ISDNTrace' set to debug level 2
OK
log ct log ctx SipPacket debug 9
OK
log output on
OK
106249.88 ISDNTrace ------
106249.88 ISDNTrace *T 00A2155A 1 NT 02 01 01 4D
106249.88 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=38 pf=1
106249.88 ISDNTrace *T 00A2155A 1 TE 02 01 01 45
106249.88 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=34 pf=1
106259.88 ISDNTrace ------
106259.88 ISDNTrace *T 00A21942 1 TE 00 01 01 45
106259.88 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 RR nr=34 pf=1
106259.88 ISDNTrace *T 00A21942 1 NT 02 01 01 4D
106259.88 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=38 pf=1
106259.88 ISDNTrace *T 00A21943 1 TE 02 01 01 45
106259.89 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=34 pf=1
106259.90 ISDNTrace ------
106259.90 ISDNTrace *T 00A21944 1 NT 00 01 01 4D
106259.90 ISDNTrace PRI-1 NT: sapi=0 cr=0 tei=0 RR nr=38 pf=1
106260.96 SipPacket PacketDump: Proto: SIP, Name: REGISTER sip:[::1]:15060 SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106260961, Content: !!!<
106260.96 SipPacket REGISTER sip:[::1]:15060 SIP/2.0 106260.96 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bK4106e8d1b89d32e5b09a49c4006dca0d.1;rport 106260.96 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106260.96 SipPacket CSeq: 30870 REGISTER 106260.96 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106260.97 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106260.97 SipPacket To: <sip:ISDNLink@[::1]:15060> 106260.97 SipPacket Max-Forwards: 70 106260.97 SipPacket Route: <sip:[::1]:15060;lr> 106260.97 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106260.97 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106260.97 SipPacket Expires: 3600 106260.97 SipPacket Supported: 100rel,timer,gruu,path,outbound 106260.97 SipPacket Content-Length: 0 106260.97 SipPacket 106260.97 SipPacket >!!!
106260.98 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106260981, Content: !!!<
106260.98 SipPacket SIP/2.0 200 OK 106260.98 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bK4106e8d1b89d32e5b09a49c4006dca0d.1;rport=35272;received=::1 106260.98 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106260.98 SipPacket CSeq: 30870 REGISTER 106260.98 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106260.98 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106260.98 SipPacket To: <sip:ISDNLink@[::1]:15060>;tag=78644659d16aa1a0 106260.98 SipPacket Server: fwd 106260.99 SipPacket Content-Length: 0 106260.99 SipPacket 106260.99 SipPacket >!!!
106269.88 ISDNTrace ------
106269.88 ISDNTrace *T 00A21D2A 1 NT 02 01 01 4D
106269.88 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=38 pf=1
106269.88 ISDNTrace *T 00A21D2A 1 TE 02 01 01 45
106269.88 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=34 pf=1
106279.88 ISDNTrace ------
106279.88 ISDNTrace *T 00A22112 1 TE 00 01 01 45
106279.88 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 RR nr=34 pf=1
106279.88 ISDNTrace *T 00A22112 1 NT 02 01 01 4D
106279.88 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=38 pf=1
106279.88 ISDNTrace *T 00A22113 1 TE 02 01 01 45
106279.89 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=34 pf=1
106279.90 ISDNTrace ------
106279.90 ISDNTrace *T 00A22114 1 NT 00 01 01 4D
106279.90 ISDNTrace PRI-1 NT: sapi=0 cr=0 tei=0 RR nr=38 pf=1
106280.98 SipPacket PacketDump: Proto: SIP, Name: REGISTER sip:[::1]:15060 SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106280978, Content: !!!<
106280.98 SipPacket REGISTER sip:[::1]:15060 SIP/2.0 106280.98 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bK3b0237a2d34263a076b1ff61bfd6725f.1;rport 106280.98 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106280.98 SipPacket CSeq: 30871 REGISTER 106280.98 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106280.98 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106280.98 SipPacket To: <sip:ISDNLink@[::1]:15060> 106280.98 SipPacket Max-Forwards: 70 106280.99 SipPacket Route: <sip:[::1]:15060;lr> 106280.99 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106280.99 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106280.99 SipPacket Expires: 3600 106280.99 SipPacket Supported: 100rel,timer,gruu,path,outbound 106280.99 SipPacket Content-Length: 0 106280.99 SipPacket 106280.99 SipPacket >!!!
106281.00 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106280999, Content: !!!<
106281.00 SipPacket SIP/2.0 200 OK 106281.00 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bK3b0237a2d34263a076b1ff61bfd6725f.1;rport=35272;received=::1 106281.00 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106281.00 SipPacket CSeq: 30871 REGISTER 106281.00 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106281.00 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106281.00 SipPacket To: <sip:ISDNLink@[::1]:15060>;tag=f7ebf84024184138 106281.00 SipPacket Server: fwd 106281.00 SipPacket Content-Length: 0 106281.00 SipPacket 106281.00 SipPacket >!!!
106289.88 ISDNTrace ------
106289.88 ISDNTrace *T 00A224FA 1 NT 02 01 01 4D
106289.88 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=38 pf=1
106289.88 ISDNTrace *T 00A224FA 1 TE 02 01 01 45
106289.88 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=34 pf=1
106297.20 ISDNTrace ------
106297.20 ISDNTrace *T 00A227D6 1 NT 02 01 44 4C 08 02 5A F8 05 04 02 88 90 18 03 A1 83 8D 6C 09 21 83 36 36 38 34 30 33 37 70 0A A1 32 33 36 36 30 39 31 35 38 A1
106297.20 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 I ns=34 nr=38 pf=0
106297.20 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=0)
106297.20 ISDNTrace SETUP
106297.20 ISDNTrace Bearer cap: 88 90
106297.20 ISDNTrace ITU-T, Unrestricted digital information, 64k circuit
106297.20 ISDNTrace Channel id: a1 83 8d
106297.20 ISDNTrace PRI, Preferred, not D-ch., as indicated
106297.20 ISDNTrace ITU-T, B-channel number 13
106297.20 ISDNTrace Clin numbr: 21 83 36 36 38 34 30 33 37
106297.20 ISDNTrace Number type : National
106297.21 ISDNTrace Number plan : ISDN/Telephony
106297.21 ISDNTrace Present. ind. : Presentation allowed
106297.21 ISDNTrace Screening ind : Network provided
106297.21 ISDNTrace Calling number: 6684037
106297.21 ISDNTrace Cled numbr: a1 32 33 36 36 30 39 31 35 38
106297.21 ISDNTrace Number type : National
106297.21 ISDNTrace Called number : 236609158
106297.21 ISDNTrace Sending complete
106297.21 ISDNTrace ------
106297.21 ISDNTrace *T 00A227D7 1 TE 02 01 01 46
106297.21 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=35 pf=0
106297.21 H320Call h320_call_handler::handleH320SACallInd - callId 1
106297.21 H320Call h320_call::outgoingAltertInd(p=1,s=1) [fe80::e6c7:22ff:fe60:a1b9]
106297.22 SipCall I: ==== makeOutgoingCall appId=2, stackId=na
106297.26 SipCall I: sip_call_handler::handleSIPMRtpLocalCapsetInd(2/-1/-1, capsetentries: 18): Received local capset with payload types set
106297.27 H320Call h320_call_handler::handleH320SAParticipantIdReq(p=1, s=1) Remote requested Participant Id
106297.28 H320Call h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 0, audioId 0, h221Individ 0
106297.28 H320Call h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 1, audioId 65535, h221Individ 0
106297.29 H320Call h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 2, audioId 65535, h221Individ 0
106297.30 H221 H221I-0 resource
106297.30 H221 H221O-0 resource
106297.30 SipPacket PacketDump: Proto: SIP, Name: INVITE sip:[fe80::e6c7:22ff:fe60:a1b9] SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106297303, Content: !!!<
106297.30 SipPacket INVITE sip:[fe80::e6c7:22ff:fe60:a1b9] SIP/2.0 106297.30 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKb2d4f3ed15d2b32c2c16a9653498205f.1;rport 106297.30 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106297.31 SipPacket CSeq: 100 INVITE 106297.31 SipPacket Contact: <sip:[fe80::e6c7:22ff:fe60:b0e9]:5061;transport=tls> 106297.31 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106297.31 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]> 106297.31 SipPacket Max-Forwards: 70 106297.31 SipPacket Route: <sip:[::1]:15060;lr> 106297.31 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106297.31 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106297.31 SipPacket Supported: 100rel,timer,gruu,path,outbound 106297.31 SipPacket Session-Expires: 1800 106297.31 SipPacket Content-Type: application/sdp 106297.31 SipPacket Content-Length: 2332 106297.31 SipPacket 106297.31 SipPacket v=0 106297.31 SipPacket o=tandberg 2 1 IN IP6 fe80::e6c7:22ff:fe60:b0e9 106297.31 SipPacket s=- 106297.31 SipPacket c=IN IP6 fe80::e6c7:22ff:fe60:b0e9 106297.31 SipPacket b=AS:1920 106297.31 SipPacket t=0 0 106297.31 SipPacket m=audio 2326 RTP/AVP 99 100 102 9 15 18 8 106297.31 SipPacket b=TIAS:64000 106297.31 SipPacket a=rtpmap:99 MP4A-LATM/90000 106297.31 SipPacket a=fmtp:99 profile-level-id=24;object=23;bitrate=64000 106297.31 SipPacket a=rtpmap:100 G7221/16000 106297.31 SipPacket a=fmtp:100 bitrate=32000 106297.32 SipPacket a=rtpmap:102 G7221/16000 106297.32 SipPacket a=fmtp:102 bitrate=24000 106297.32 SipPacket a=rtpmap:9 G722/8000 106297.32 SipPacket a=rtpmap:15 G728/8000 106297.32 SipPacket a=rtpmap:18 G729/8000 106297.32 SipPacket a=fmtp:18 annexb=no 106297.32 SipPacket a=rtpmap:8 PCMA/8000 106297.32 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:kS7sw4pSeg3bh9Ym+rhh2XOg9VbT+wbfeZ3+pMfn|2^48 106297.32 SipPacket a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:kS7sw4pSeg3bh9Ym+rhh2XOg9VbT+wbfeZ3+pMfn|2^48 UNENCRYPTED_SRTCP 106297.32 SipPacket a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:OFH5NPbcyKCkYYywz10HCTHopn/fGLgNi438RtTr|2^48 106297.32 SipPacket a=sendrecv 106297.32 SipPacket m=video 2338 RTP/AVP 97 98 34 31 106297.32 SipPacket b=TIAS:1920000 106297.32 SipPacket a=rtpmap:97 H264/90000 106297.32 SipPacket a=fmtp:97 profile-level-id=42800d;max-br=1600;max-mbps=108000;max-fs=3600;max-smbps=108000;max-fps=6000 106297.32 SipPacket a=rtpmap:98 H263-1998/90000 106297.32 SipPacket a=fmtp:98 custom=352,240,1;qcif=1;maxbr=19200 106297.32 SipPacket a=rtpmap:34 H263/90000 106297.32 SipPacket a=fmtp:34 qcif=1;maxbr=19200 106297.32 SipPacket a=rtpmap:31 H261/90000 106297.32 SipPacket a=fmtp:31 qcif=1;maxbr=19200 106297.32 SipPacket a=rtcp-fb:* nack pli 106297.32 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:KVGSj45SBJ73RhbrS7cY+WWIqiiws6gPm8yE5J2n|2^48 106297.32 SipPacket a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:KVGSj45SBJ73RhbrS7cY+WWIqiiws6gPm8yE5J2n|2^48 UNENCRYPTED_SRTCP 106297.32 SipPacket a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:wrGiWfj1Z22oPn/NAVPtRu9YzoX5MjIV+CukHezq|2^48 106297.32 SipPacket a=sendrecv 106297.33 SipPacket a=content:main 106297.33 SipPacket a=label:11 106297.33 SipPacket a=answer:full 106297.33 SipPacket m=application 5070 UDP/BFCP * 106297.33 SipPacket a=floorctrl:c-s 106297.33 SipPacket a=confid:1 106297.33 SipPacket a=floorid:2 mstrm:12 106297.33 SipPacket a=userid:2 106297.33 SipPacket a=setup:actpass 106297.33 SipPacket a=connection:new 106297.33 SipPacket m=video 2350 RTP/AVP 97 98 34 31 106297.33 SipPacket b=TIAS:1920000 106297.33 SipPacket a=rtpmap:97 H264/90000 106297.33 SipPacket a=fmtp:97 profile-level-id=42800d;max-br=1600;max-mbps=108000;max-fs=3600;max-smbps=108000;max-fps=6000 106297.33 SipPacket a=rtpmap:98 H263-1998/90000 106297.33 SipPacket a=fmtp:98 custom=352,240,1;qcif=1;maxbr=19200 106297.33 SipPacket a=rtpmap:34 H263/90000 106297.33 SipPacket a=fmtp:34 qcif=1;maxbr=19200 106297.33 SipPacket a=rtpmap:31 H261/90000 106297.33 SipPacket a=fmtp:31 qcif=1;maxbr=19200 106297.33 SipPacket a=rtcp-fb:* nack pli 106297.33 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:f5f67vbxKcbEkpprMb8oWKId2zJuxwtgA62QwM11|2^48 106297.33 SipPacket a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:f5f67vbxKcbEkpprMb8oWKId2zJuxwtgA62QwM11|2^48 UNENCRYPTED_SRTCP 106297.33 SipPacket a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:KR0Fyt5ladIfeLkxOpQnrJKM01GMBzULurNs5+m+|2^48 106297.34 SipPacket a=sendrecv 106297.34 SipPacket a=content:slides 106297.34 SipPacket a=label:12 106297.34 SipPacket >!!!
106297.34 ISDNTrace ------
106297.34 ISDNTrace *T 00A227E4 1 TE 00 01 4C 46 08 02 DA F8 01
106297.34 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 I ns=38 nr=35 pf=0
106297.34 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=1)
106297.34 ISDNTrace ALERTING
106297.41 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 180 Ringing, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106297408, Content: !!!<
106297.41 SipPacket SIP/2.0 180 Ringing 106297.41 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKb2d4f3ed15d2b32c2c16a9653498205f.1;rport 106297.41 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106297.41 SipPacket CSeq: 100 INVITE 106297.41 SipPacket Contact: <sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls>;sip.ice=TRUE 106297.41 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106297.41 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]>;tag=62c97e300e63af9d 106297.41 SipPacket Record-Route: <sip:[fe80::e6c7:22ff:fe60:b0e9]:15070;transport=tls;lr> 106297.41 SipPacket Record-Route: <sip:[::1]:15060;transport=tls;lr> 106297.41 SipPacket Server: TANDBERG/521 (TC7.2.1.cb31c3d) 106297.41 SipPacket Content-Length: 0 106297.41 SipPacket 106297.41 SipPacket >!!!
106297.42 SipCall I: sip_call_handler::SIPM_Alert_Ind (2/0/-1)
106297.53 ISDNTrace ------
106297.53 ISDNTrace *T 00A227F7 1 NT 00 01 01 4E
106297.53 ISDNTrace PRI-1 NT: sapi=0 cr=0 tei=0 RR nr=39 pf=0
106301.00 SipPacket PacketDump: Proto: SIP, Name: REGISTER sip:[::1]:15060 SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106300996, Content: !!!<
106301.00 SipPacket REGISTER sip:[::1]:15060 SIP/2.0 106301.00 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKbebc781b06d1ccd05d59d81022c1dbef.1;rport 106301.00 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106301.00 SipPacket CSeq: 30872 REGISTER 106301.00 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106301.00 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106301.00 SipPacket To: <sip:ISDNLink@[::1]:15060> 106301.00 SipPacket Max-Forwards: 70 106301.00 SipPacket Route: <sip:[::1]:15060;lr> 106301.00 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106301.00 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106301.00 SipPacket Expires: 3600 106301.00 SipPacket Supported: 100rel,timer,gruu,path,outbound 106301.00 SipPacket Content-Length: 0 106301.00 SipPacket 106301.00 SipPacket >!!!
106301.01 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106301011, Content: !!!<
106301.01 SipPacket SIP/2.0 200 OK 106301.01 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKbebc781b06d1ccd05d59d81022c1dbef.1;rport=35272;received=::1 106301.01 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106301.01 SipPacket CSeq: 30872 REGISTER 106301.01 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106301.01 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106301.01 SipPacket To: <sip:ISDNLink@[::1]:15060>;tag=a08f91c571d4c336 106301.01 SipPacket Server: fwd 106301.01 SipPacket Content-Length: 0 106301.02 SipPacket 106301.02 SipPacket >!!!
106303.76 Bfcp I: bfcp_Ready_doBFCPHelloInd session not found userId=10
106303.77 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106303772, Content: !!!<
106303.77 SipPacket SIP/2.0 200 OK 106303.77 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKb2d4f3ed15d2b32c2c16a9653498205f.1;rport 106303.77 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106303.78 SipPacket CSeq: 100 INVITE 106303.78 SipPacket Contact: <sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls>;sip.ice=TRUE 106303.78 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106303.78 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]>;tag=62c97e300e63af9d 106303.78 SipPacket Record-Route: <sip:[fe80::e6c7:22ff:fe60:b0e9]:15070;transport=tls;lr> 106303.78 SipPacket Record-Route: <sip:[::1]:15060;transport=tls;lr> 106303.78 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,REFER,NOTIFY 106303.78 SipPacket Server: TANDBERG/521 (TC7.2.1.cb31c3d) 106303.78 SipPacket Supported: replaces,100rel,timer,gruu,path,outbound 106303.78 SipPacket Require: timer 106303.78 SipPacket Session-Expires: 1800;refresher=uas 106303.78 SipPacket Min-SE: 90 106303.78 SipPacket Content-Type: application/sdp 106303.78 SipPacket Content-Length: 2416 106303.78 SipPacket 106303.78 SipPacket v=0 106303.78 SipPacket o=tandberg 10 1 IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.78 SipPacket s=- 106303.78 SipPacket b=AS:1920 106303.78 SipPacket t=0 0 106303.78 SipPacket m=audio 2382 RTP/AVP 99 100 102 9 15 18 8 106303.78 SipPacket c=IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.78 SipPacket b=TIAS:64000 106303.78 SipPacket a=rtpmap:99 MP4A-LATM/90000 106303.79 SipPacket a=fmtp:99 profile-level-id=24;object=23;bitrate=64000 106303.79 SipPacket a=rtpmap:100 G7221/16000 106303.79 SipPacket a=fmtp:100 bitrate=32000 106303.79 SipPacket a=rtpmap:102 G7221/16000 106303.79 SipPacket a=fmtp:102 bitrate=24000 106303.79 SipPacket a=rtpmap:9 G722/8000 106303.79 SipPacket a=rtpmap:15 G728/8000 106303.79 SipPacket a=rtpmap:18 G729/8000 106303.79 SipPacket a=fmtp:18 annexb=no 106303.79 SipPacket a=rtpmap:8 PCMA/8000 106303.79 SipPacket a=rtcp:2383 IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.79 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:o/b4x8oQI/TBCzjYA5gHvUDQmHT8ARnLXRE6rpAB|2^48 106303.79 SipPacket a=sendrecv 106303.79 SipPacket m=video 2384 RTP/AVP 97 98 34 106303.79 SipPacket c=IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.79 SipPacket b=TIAS:1920000 106303.79 SipPacket a=rtpmap:97 H264/90000 106303.79 SipPacket a=fmtp:97 packetization-mode=0;profile-level-id=428014;max-br=3333;max-mbps=116000;max-fs=3840;max-smbps=116000;max-fps=3000;max-rcmd-nalu-size=1474560;sar-supported=16 106303.79 SipPacket a=rtpmap:98 H263-1998/90000 106303.79 SipPacket a=fmtp:98 custom=1280,768,1;custom=1280,720,1;custom=1024,768,1;custom=1024,576,1;custom=800,600,1;cif4=1;custom=720,480,1;custom=640,480,1;custom=512,288,1;cif=1;custom=352,240,1;qcif=1;maxbr=19200 106303.79 SipPacket a=rtpmap:34 H263/90000 106303.79 SipPacket a=fmtp:34 cif4=2;cif=1;qcif=1;maxbr=19200 106303.79 SipPacket a=rtcp:2385 IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.79 SipPacket a=label:11 106303.79 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:44JlePfuWbyKR9EzWRgUl2WpwV/Qbu9NBxwv3ToB|2^48 106303.80 SipPacket a=content:main 106303.80 SipPacket a=rtcp-fb:* nack pli 106303.80 SipPacket a=rtcp-fb:* ccm fir 106303.80 SipPacket a=rtcp-fb:* ccm tmmbr 106303.80 SipPacket a=sendrecv 106303.80 SipPacket m=application 2444 UDP/BFCP * 106303.80 SipPacket c=IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.80 SipPacket a=setup:passive 106303.80 SipPacket a=confid:1 106303.80 SipPacket a=userid:10 106303.80 SipPacket a=floorid:2 mstrm:12 106303.80 SipPacket a=floorctrl:s-only 106303.80 SipPacket a=connection:new 106303.80 SipPacket m=video 2386 RTP/AVP 97 98 34 106303.80 SipPacket c=IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.80 SipPacket b=TIAS:1920000 106303.80 SipPacket a=rtpmap:97 H264/90000 106303.80 SipPacket a=fmtp:97 packetization-mode=0;profile-level-id=42800d;max-br=1666;max-mbps=116000;max-fs=3840;max-smbps=116000;max-fps=3000;max-rcmd-nalu-size=1474560;sar-supported=16 106303.80 SipPacket a=rtpmap:98 H263-1998/90000 106303.80 SipPacket a=fmtp:98 custom=1280,768,1;custom=1280,720,1;custom=1024,768,1;custom=1024,576,1;custom=800,600,1;cif4=1;custom=720,480,1;custom=640,480,1;custom=512,288,1;cif=1;custom=352,240,1;qcif=1;maxbr=19200 106303.80 SipPacket a=rtpmap:34 H263/90000 106303.80 SipPacket a=fmtp:34 cif4=2;cif=1;qcif=1;maxbr=19200 106303.80 SipPacket a=rtcp:2387 IN IP6 fe80::e6c7:22ff:fe60:a1b9 106303.80 SipPacket a=label:12 106303.80 SipPacket a=crypto:0 AES_CM_128_HMAC_SHA1_80 inline:KH+G8WMWSF9iKLpDvwVlS6N3Sp75Mg4yTLlLL1ZF|2^48 106303.80 SipPacket a=content:slides 106303.81 SipPacket a=rtcp-fb:* nack pli 106303.81 SipPacket a=rtcp-fb:* ccm fir 106303.81 SipPacket a=rtcp-fb:* ccm tmmbr 106303.81 SipPacket a=sendrecv 106303.81 SipPacket >!!!
106303.81 SipCall I: sip_call_handler::log_call_cnf(na/0/-1): Incoming callrate=0
106303.82 SipCall I: sip_call_handler::handleSIPMCallCnf(2/0/-1): Call confirmed (ACK received, remoteName: [fe80, remoteURI: sip:[fe80::e6c7:22ff:fe60:a1b9], received_302_301: 0)
106303.83 SipCall I: Setting remote abilities
106303.85 SipCall I: ==== affirmOutgoingCall appId=2, stackId=0, eventCookie=-1
106303.85 H320Call h320_call::acceptIncomingCall(p=1,s=1) local=h320:236609158 callrate=1920000
106303.85 H320Call h320_call::acceptIncomingCall AppId set 1
106303.85 SipPacket PacketDump: Proto: SIP, Name: ACK sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106303854, Content: !!!<
106303.86 SipPacket ACK sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls SIP/2.0 106303.86 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKb6607c3d4f8aa9d834166339f17d0de6.1;rport 106303.86 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106303.86 SipPacket CSeq: 100 ACK 106303.86 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106303.86 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]>;tag=62c97e300e63af9d 106303.86 SipPacket Max-Forwards: 70 106303.86 SipPacket Route: <sip:[::1]:15060;transport=tls;lr> 106303.86 SipPacket Route: <sip:[fe80::e6c7:22ff:fe60:b0e9]:15070;transport=tls;lr> 106303.86 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106303.86 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106303.86 SipPacket Supported: 100rel,timer,gruu,path,outbound 106303.86 SipPacket Content-Length: 0 106303.86 SipPacket 106303.86 SipPacket >!!!
106303.86 ISDNTrace ------
106303.86 ISDNTrace *T 00A22A71 1 TE 00 01 4E 46 08 02 DA F8 07
106303.86 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 I ns=39 nr=35 pf=0
106303.86 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=1)
106303.86 ISDNTrace CONNECT
106303.88 RTP I: RtpSession_EnableTMMBx, (sid=1)
106303.88 RTP I: RtpSession_EnableTMMBx, (sid=2)
106303.89 ISDNTrace ------
106303.89 ISDNTrace *T 00A22A73 1 NT 02 01 46 50 08 02 5A F8 0F
106303.89 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 I ns=35 nr=40 pf=0
106303.89 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=0)
106303.89 ISDNTrace CONNECT ACKNOWLEDGE
106303.89 ISDNTrace *T 00A22A73 1 TE 02 01 01 48
106303.89 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=36 pf=0
106303.89 H320Call h320_call_handler::handleH320SACallResAck - stackId 1 channelMap 0x1000
106303.90 H320Call h320_call_handler::handleH320SAOutModeEncrRequest callid 1
106303.90 BONDING BFG-0: 1 Ch: 0(12),
106303.90 BONDING BLL-0: Func bll_Init
106303.90 BONDING BLL-0: 1 Ch/Cid: 0(12)/0,
106303.90 BONDING BFG-0 (BCH-12): InfoReq
106303.92 BONDING BFG-0: Outgoing: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF: Invalid ALIGN byte (ff)
106303.99 RTP I: validateNewSSRC(sid=0) registering new ssrc (5d945221)
106304.00 RTP I: validateNewSSRC(sid=1) registering new ssrc (78a51c96)
106304.48 BONDING BLL-0: Full IC ch 0(12), CID: 0
106304.49 BONDING BLL-0: Incoming 0(12): 7F 81 81 9F 8D FD 81 81 FF FF FF FF FF FF FF FF: CID=0, GID=0, Mode=1, N=6, 64 kbit/s, RI=0, Sm=7, Rev=0, Sub=0, XFLAG=63
106304.49 BONDING BNEG-0: Bonding status Id:Outgoing disconnect Cause:Failure no recovery N:6 ReqN:30
106304.49 BONDING BNEG-0: Bonding status Id:Outgoing disconnect Cause:Too few channels N:6 ReqN:30
106304.49 BONDING BFG-0 (BCH-12): InfoReq
106304.50 BONDING BFG-0: Outgoing: 7F 81 83 9F 81 8D 81 81 FF FD 99 FF FF FF FF FF: CID=0, GID=1, Mode=1, N=0, 64 kbit/s, RI=0, Sm=0, Rev=0, Sub=0, XFLAG=63, Disconnecting, cause=Failure, no recovery
106305.13 BONDING BLL-0: Incoming 0(12): 7F 81 81 9F 81 FD 81 81 FF FF FF FF FF FF FF FF: CID=0, GID=0, Mode=1, N=0, 64 kbit/s, RI=0, Sm=7, Rev=0, Sub=0, XFLAG=63
106309.49 BONDING BFG-0: 0 Ch:
106309.49 BONDING BFG-0 (BFG-0): Terminate
106309.49 BONDING BChanTable->wSize 1!
106309.49 BONDING BChan 12 at j = 0!
106309.50 BONDING BLL-0: 0 Ch/Cid:
106309.50 BONDING BLL-0 (BLL-0): Terminate
106309.50 H320Call h320_call_handler::handleH320SADiscInd(p=1, s=1) Received disconnect indication
106309.51 SipCall I: ==== outgoingDisconnect appId=2, stackId=0, eventCookie=-1, (sipCause.dc=-1, sipCause.status=0)
106309.51 H320Call h320_call::affirmIncomingDisconnect(p=1,s=1)
106309.51 ISDNTrace ------
106309.52 ISDNTrace *T 00A22CA6 1 TE 00 01 50 48 08 02 DA F8 45 08 02 80 90
106309.52 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 I ns=40 nr=36 pf=0
106309.52 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=1)
106309.52 ISDNTrace DISCONNECT
106309.52 ISDNTrace Cause: 80 90
106309.52 ISDNTrace ITU-T Q.931, User
106309.52 ISDNTrace Normal clearing (16)
106309.52 SipPacket PacketDump: Proto: SIP, Name: BYE sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106309523, Content: !!!<
106309.52 SipPacket BYE sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls SIP/2.0 106309.52 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKeaa1ef3d885dd268f5731ee01833c053.1;rport 106309.52 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106309.53 SipPacket CSeq: 101 BYE 106309.53 SipPacket Contact: <sip:[fe80::e6c7:22ff:fe60:b0e9]:5061;transport=tls> 106309.53 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106309.53 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]>;tag=62c97e300e63af9d 106309.53 SipPacket Max-Forwards: 70 106309.53 SipPacket Route: <sip:[::1]:15060;transport=tls;lr> 106309.53 SipPacket Route: <sip:[fe80::e6c7:22ff:fe60:b0e9]:15070;transport=tls;lr> 106309.53 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106309.53 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106309.53 SipPacket Supported: 100rel,timer,gruu,path,outbound 106309.53 SipPacket Content-Length: 0 106309.53 SipPacket 106309.53 SipPacket >!!!
106309.53 SipCall I: sip_call_handler::handleSIPMDiscCnf(2/0/-1): Disconnect confirm
106309.54 ISDNTrace ------
106309.54 ISDNTrace *T 00A22CA8 1 NT 02 01 48 52 08 02 5A F8 4D
106309.54 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 I ns=36 nr=41 pf=0
106309.54 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=0)
106309.54 ISDNTrace RELEASE
106309.54 ISDNTrace *T 00A22CA8 1 TE 02 01 01 4A
106309.54 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=37 pf=0
106309.55 SipMedia ERROR: Sipmedia. Could not find session, for userid=2
106309.55 ISDNTrace ------
106309.55 ISDNTrace *T 00A22CA9 1 TE 00 01 52 4A 08 02 DA F8 5A
106309.55 ISDNTrace PRI-1 TE: sapi=0 cr=0 tei=0 I ns=41 nr=37 pf=0
106309.55 ISDNTrace pd=8 (Q.931) cref=23288 (hex=5AF8,f=1)
106309.55 ISDNTrace RELEASE COMPLETE
106309.55 H320Call ERROR: h320_call_handler::handleH320SADiscCnf() Received disconnect confirm for non-existing call (stackid: 1)
106309.68 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 2e8c84c2eb23b7e1a681668aae962fb3, Time: 106309675, Content: !!!<
106309.68 SipPacket SIP/2.0 200 OK 106309.68 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKeaa1ef3d885dd268f5731ee01833c053.1;rport 106309.68 SipPacket Call-ID: 2e8c84c2eb23b7e1a681668aae962fb3 106309.68 SipPacket CSeq: 101 BYE 106309.68 SipPacket Contact: <sip:[fe80::e6c7:22ff:fe60:a1b9]:5061;transport=tls>;sip.ice=TRUE 106309.68 SipPacket From: "6684037" <sip:[fe80::e6c7:22ff:fe60:b0e9];x-h320number=6684037>;tag=ae61136ad20385c0 106309.68 SipPacket To: <sip:[fe80::e6c7:22ff:fe60:a1b9]>;tag=62c97e300e63af9d 106309.68 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,REFER,NOTIFY 106309.68 SipPacket Server: TANDBERG/521 (TC7.2.1.cb31c3d) 106309.68 SipPacket Supported: replaces,100rel,timer,gruu,path,outbound 106309.68 SipPacket Content-Length: 0 106309.68 SipPacket 106309.68 SipPacket >!!!
106309.73 ISDNTrace ------
106309.73 ISDNTrace *T 00A22CBB 1 NT 00 01 01 54
106309.73 ISDNTrace PRI-1 NT: sapi=0 cr=0 tei=0 RR nr=42 pf=0
106310.55 H221 H221I-0 resource
106310.55 H221 H221O-0 resource
106310.56 H221 H221O-0 resource
106319.53 ISDNTrace ------
106319.53 ISDNTrace *T 00A2308F 1 NT 02 01 01 55
106319.53 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=42 pf=1
106319.54 ISDNTrace *T 00A23090 1 TE 02 01 01 4B
106319.54 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=37 pf=1
106321.01 SipPacket PacketDump: Proto: SIP, Name: REGISTER sip:[::1]:15060 SIP/2.0, Direction: Outgoing, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106321013, Content: !!!<
106321.01 SipPacket REGISTER sip:[::1]:15060 SIP/2.0 106321.02 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKfa7fa76f90ecf41a4db7af08f2ec9cb0.1;rport 106321.02 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106321.02 SipPacket CSeq: 30873 REGISTER 106321.02 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106321.02 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106321.02 SipPacket To: <sip:ISDNLink@[::1]:15060> 106321.02 SipPacket Max-Forwards: 70 106321.02 SipPacket Route: <sip:[::1]:15060;lr> 106321.02 SipPacket Allow: INVITE,ACK,CANCEL,BYE,UPDATE,INFO,OPTIONS,NOTIFY 106321.02 SipPacket User-Agent: TANDBERG/82 (IL1.1.4.c6ff645) 106321.02 SipPacket Expires: 3600 106321.02 SipPacket Supported: 100rel,timer,gruu,path,outbound 106321.02 SipPacket Content-Length: 0 106321.02 SipPacket 106321.02 SipPacket >!!!
106321.03 SipPacket PacketDump: Proto: SIP, Name: SIP/2.0 200 OK, Direction: Incoming, RemoteAddress: [::1]:15060, GroupEntity: 5d6d63df9912fdb406d2041059096211, Time: 106321031, Content: !!!<
106321.03 SipPacket SIP/2.0 200 OK 106321.03 SipPacket Via: SIP/2.0/TLS [fe80::e6c7:22ff:fe60:b0e9]:5061;branch=z9hG4bKfa7fa76f90ecf41a4db7af08f2ec9cb0.1;rport=35272;received=::1 106321.03 SipPacket Call-ID: 5d6d63df9912fdb406d2041059096211 106321.03 SipPacket CSeq: 30873 REGISTER 106321.03 SipPacket Contact: <sip:ISDNLink@10.134.84.57:5061;transport=tls>;+sip.instance="<urn:uuid:98085d95-1930-56ae-a0cc-ec63a981c735>" 106321.03 SipPacket From: <sip:ISDNLink@[::1]:15060>;tag=f28886fd2c55fcbf 106321.03 SipPacket To: <sip:ISDNLink@[::1]:15060>;tag=84ea01057126e199 106321.04 SipPacket Server: fwd 106321.04 SipPacket Content-Length: 0 106321.04 SipPacket 106321.04 SipPacket >!!!
systemtools calltrace o106329.53 ISDNTrace ------
106329.53 ISDNTrace *T 00A23477 1 NT 02 01 01 55
106329.53 ISDNTrace PRI-1 NT: sapi=0 cr=1 tei=0 RR nr=42 pf=1
106329.53 ISDNTrace *T 00A23477 1 TE 02 01 01 4B
106329.53 ISDNTrace PRI-1 TE: sapi=0 cr=1 tei=0 RR nr=37 pf=1
ff
Log context 'BONDING' set to debug level 0
Log context 'H221' set to debug level 0
Log context 'H242' set to debug level 0
Log context 'H320Call' set to debug level 0
Log context 'H320Crypto' set to debug level 0
Log context 'ISDNTrace' set to debug level 0
OK
log output off
OK
