12-30-2012 10:13 PM - edited 03-18-2019 12:20 AM
Hello!
Is there an admin guide for the new iPad version? I can only find one for the 9.1 version:
which does not describe the auto discovery function done for the "email style" login.
I can see there are some lookups done:
TXT? domain.com.
SRV? _cuplogin._tcp.domain.com.
SRV? _xmpp-client._tcp.domain.com.
SRV? _cisco-phone-tftp._tcp.domain.com.
SRV? _cisco-phone-http._tcp.domain.com.
SRV? _sips._tcp.internal.domain.com.
SRV? _sip._tcp.internal.domain.com.
SRV? _sips._tcp.external.domain.com.
SRV? _sip._tcp.external.domain.com.
SRV? _ciscoedge._tcp.domain.com.
SRV? _ciscowtp._tcp.domain.com.
SRV? _ciscowtp._tcp.jabber.com.
SRV? _ciscowtp._tcp.webex.com.
It works fine for me if I set the _sips._tcp.external.domain.com. pointing to my vcse.
Some explanation could be handy, expecially what the TXT lookup is doing.
Solved! Go to Solution.
01-10-2013 03:28 PM
Hello Martin!
I realize your question is a couple of weeks old and I believe since then, the Jabber for the iPad team has posted the latest admin guide which has been updated for the 9.2 release. Check out the "Setup DNS SRV" section as it might explain what you are looking for - I am not sure how this section differs from the previous guide...
For the benefit of others who have Jabber for the iPad specific questions, please note the Jabber Clients community is available.
HTH,
Paula
01-10-2013 03:28 PM
Hello Martin!
HTH,
Paula
01-10-2013 11:17 PM
thx Paula :-)
Yes, the question might also have been placed in the Jabber/iPad section, but for me
thats more how the infrastructure has to handle it so I decided to place it here.
For others who were also wondering, the TXT entry is used following the SPF format to
define the used services.
But it also works without just trying the services untill it finds the configured one.
Think it would be handy if the other JabberVideo clients would also add support for that.
