11-07-2017 10:11 AM - edited 03-18-2019 01:36 PM
Not getting acano> prompt when logging into the MMP for the first time.
Assigned ip to the CMS200-MMP-CIMC ip-pool (block), however when I SSH, I am met with;
Cisco Serial Over LAN:
Close Network Connection to Exit
No acano> prompt for further configuration.
11-07-2017 11:51 AM
Have you double checked that you've configured the UCS correct in section 3 of the CMS 2000 Install Guide?
11-07-2017 12:22 PM - edited 11-07-2017 12:29 PM
Yes, I have assigned IPs all in same subnet
UCS-A 172.16.1.10
UCS-B 172.16.1.11
MMP 172.16.1.12
Powered everything on and set interface speeds.
Able to get to the MMP but no acano> prompt to facilitate any syntax.
I have access to KVM and BIOS, but not seeing anything ill configured.
How is CMS2000-MMP (vif/vNIC) configured in UCS Manager?
Is there a way to restore back to factory settings anb start config over?
Is there a way to confirm that the acano firmware/software is even present?
