12-20-2017 10:26 AM - edited 03-18-2019 01:42 PM
I have been assigned to deploy the Cisco Meeting Server, replacing 5320MCU.
-license activated
-Integrated with CUCM 10.5.2-SIP trunk created
-SIP trunk to VCS created for h323 end points
-certs created
-webadmin, webbride and callbridge configured
-dns records created
-created space (configured a few test conferences)
-successful conf bridge test
login to WebRTC with xmpp credentials receiving (system maintenance - try again later) message
is this because authentication with xmpp has not been established?
currently using xmpp for lync
Any help or guidance is appreciated!
single server appliance user for internal users
Solved! Go to Solution.
12-20-2017 12:49 PM
Yes, you need to configure LDAP in order to sync your users, and you need to configure XMPP (and see the XMPP connection status as connected) before you can authenticate via CMA or WebRTC with users.
12-20-2017 08:59 PM
You need to configure XMPP on CMS and then import users into CMS from AD. The steps to configure XMPP and importing users from AD are covered in the CMS Single Combined Deployment Guides.
12-20-2017 12:49 PM
12-20-2017 08:59 PM
