06-13-2020 04:43 AM
i installed CUCM 12.5 and Cisco meeting server 2.9.1 and i configured new Conference bridge with cms,
cisco meeting server event logs:
127.0.0.1:58164: API user "admin" created new space 0268291a-de1d-49c1-82d4-7080d4ed22d3 (001229090007) | |||
2020-06-13 | 15:55:24.364 | Info | call create failed to find coSpace -- attempting to retrieve from database |
2020-06-13 | 15:55:24.369 | Info | conference 36bc1610-e24a-46e1-b0ab-be0cd17b61bf: locked due to lack of lock consensus |
2020-06-13 | 15:55:24.369 | Info | conference 36bc1610-e24a-46e1-b0ab-be0cd17b61bf: lock state has changed to locked |
2020-06-13 | 15:55:24.369 | Info | API "001229090007" Space GUID: 0268291a-de1d-49c1-82d4-7080d4ed22d3 <--> Call Correlator GUID: c10bd35c-6835-4129-820a-06416313443f <--> Internal GUID: 36bc1610-e24a-46e1-b0ab-be0cd17b61bf |
2020-06-13 | 15:55:24.369 | Info | conference 36bc1610-e24a-46e1-b0ab-be0cd17b61bf: lock state has changed to unlocked |
2020-06-13 | 15:55:24.369 | Info | 127.0.0.1:58166: API user "admin" created new call 8af2e4b2-c941-4d88-acf2-f737cf47992a |
2020-06-13 | 15:55:24.382 | Info | call 14: incoming SIP call from "sip:2001@172.17.54.33" to local URI "sip:001229090007@mci-lan-cms.mcci.local:5060" / "sip:001229090007@mci-lan-cms.mcci.local" |
2020-06-13 | 15:55:24.394 | Info | call 14: ending; local teardown, destination URI not matched - not connected after 0:00 |
2020-06-13 | 15:55:24.394 | Info | call 14: destroying API call leg 00000000-0000-0000-0000-000000000000 |
2020-06-13 | 15:55:24.467 | Info | 127.0.0.1:58170: API user "admin" deleted space 0268291a-de1d-49c1-82d4-7080d4ed22d3 (001229090007) |
06-25-2020 11:59 AM
Hi. Can you try adding the domain portion to the incoming dial plan rules to see if the calls connect? If the dial plan is already there, can you make sure it targets cospaces? Does this solve your issue? The server is saying the URI doesn't match and sometimes this is caused that the inbound dial plan rule isn't there to accept that domain. Hope this helps?
VR
P2
05-09-2021 03:28 PM
Hi m.soleimani;
Did u find an answer to that problem, I have the same issue
