Cisco Meeting Server Management Platform
msamadpour
Our organization requires us to support multi-tenancy, multiple LDAP sources, mappings, user profiles, etc. with the Cisco Meeting Server platform.
Though the use of the API is effective, it is not efficient for large-scale deployments.
Prior to the re-branding and acquisition, Acano Manager was a supported product and worked seamlessly with the Acano/CMS platform.
Is there a supported management product (one that can support the creation and management of multi-tenancy, profiles, etc.)?
If not, does anyone know of a roadmap/timeline of such a supported application?
Jaime Valencia
Roadmap items cannot be discussed at CSC as those are NDA material.
If you're a partner, you'd need to ask in the partner communities, if not, you'd need to reach out to your SE for roadmap information.
java
if this helps, please rate
Patrick Sparkman
I don't know what features it has, but since you mentioned Acano Manager, there is a new version that supports CMS.
Acano Manager 2.x
For the time being, we are running with a trial version of the latest Acano Manager. There are a few issues, but those are being addressed by the Engineering/Development on the Acano Manager side.
Still awaiting some form of official statement from Cisco with regards to an officially supported application.
I suspect CMS will be rolled into the Cisco Prime Collaboration platform, but that is only my personal suspicion.
VQ produced the original Acano Manager product and OEM'd AM 1.x to Acano. With the Cisco acquisition of Acano, the OEM relationship came to an end but VQ still has a good working relationship with Cisco. VQ recently, for example, became a member of the Cisco Solution Partner Program with Acano Manager 2. Acano Manager 2 (released in April 2016) now hosts some of the biggest CMS deployments; one of the biggest, for example, hosted in excess of 900 thousand calls and over 28 million call minutes in October. CMS and Acano Manager 2 are now widely (over 100 AM 2.x systems) deployed and delivering great results; users love the in-call experience delivered by CMS as the call volume numbers above show.
