02-02-2017 04:16 AM - edited 03-18-2019 06:50 AM
I have Cisco Mx300 2nd with two table microphones in the table, and one microphone stays red while the other is fine, i swapped them around and the same mic still does the same, i am not sure what will be the problem.
Solved! Go to Solution.
02-02-2017 09:22 AM
If one microphone is working while the other isn't, it sounds as if the problematic microphone needs to be replaced. There was at one point an issue with microphones and the LED status being incorrect or not working, but as you have two microphones and one is working as expected, I don't believe that might be the case. I'd also check to see if the cable itself has been damaged in any way, otherwise, probably request a replacement through TAC.
02-02-2017 09:22 AM
02-02-2017 05:18 PM
I have seen this happen on a number of occasions when the users have damaged the microphone cable, either by wrapping it up too tightly, or bending it past its sensible bend radius - this breaks the conductors within the cable causing a gap or a short and giving the microphone this type of behaviour. I have two of them in my office that have been broken in this way.
The only way to fix it is to buy a new microphone.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-02-2017 10:03 PM
Hi there,
thank you for your help, i also think the solution is to buy another microphone, much appreciated
