07-23-2021 01:27 PM
07-23-2021 07:20 PM
No you can't. You can use CS-T10-WM-BR on CS-T10-WM-K9=.
CS-T10-TS+ is a table version.
07-25-2021 01:03 PM
So is there way to to order the Webex Room KIT PRO with the CS-T10-WM-K9= instead of the CS-T10-TS+?
I didn't see it as a configuration option.
07-25-2021 06:11 PM
CS-T10-WM-K9= need to order separately.
There is no bundled package and Cs kit with Room Navigator doesn't have option to select Wall Mount version. Its not a common scenario.
