Cisco room kit mini auto reset once a week.
Does any one know if its possible to add a script that makes the Room Kit Mini restart once a week?
Mathias
Roger Kallberg
VIP Expert VIP Expert
VIP Expert
Very likely you should be able to achieve this with a macro on the device. I have no suggestion for how to craft this macro, but with a little bit of search you should be able to to find the API documentation and it should contain the needed information.
Response Signature
Roger Kallberg
VIP Expert
This link should be able to get you started.
Response Signature
Ashish Patel
Maybe xCommand https://roomos.cisco.com/xapi/Command.SystemUnit.FactoryReset/? . test and play first locally
Response Signature
Looks like you can use this command to restart it: xCommand SystemUnit Boot Action: restart, Force: true
Only need to find a way for it to do it once a week.
