Cisco room kit mini auto reset once a week.
mathias jorgensen
Community Member
Does any one know if its possible to add a script that makes the Room Kit Mini restart once a week?
Mathias
10 Replies 10
Very likely you should be able to achieve this with a macro on the device. I have no suggestion for how to craft this macro, but with a little bit of search you should be able to to find the API documentation and it should contain the needed information.
Response Signature
This link should be able to get you started.
Response Signature
Ashish Patel
Maybe xCommand https://roomos.cisco.com/xapi/Command.SystemUnit.FactoryReset/? . test and play first locally 🙂
Response Signature
mathias jorgensen
Community Member
Looks like you can use this command to restart it: xCommand SystemUnit Boot Action: restart, Force: true
Only need to find a way for it to do it once a week.
Matteo Battista
Community Member
I've managed to "develop" (thanks to the documentation) a script, via-Macros, that:
> reboot the CiscoRoom (of one of our customer) every Friday (at 9pm);
> and send Webex-Message (to me).
I hope it can help; Ciao!
I attempted to use this script, but keep getting a compile Error when I upload the macro.  Points to line 35| const friday = 5.  Do you see anything wrong with this?  Also, Do you know what it should look like if I want to reboot everyday?
  33 |
  34 |     const token = //https://github.com/CiscoDevNet/roomdevices-macros-samples/blob/master/Library%20-%20Send%20Webex%20Message/README.md
> 35 |     const friday = 5;
  36 |     //sunday=0;monday=1;tuesday=2;wednesday=3;thursday=4;friday=5;saturday=6
  37 |     const rebootTime = "06:00";
The error is not with the "const friday = 5" line, it is that there is no token provided after the "const token =", the rest of that line is a comment, so there is nothing being defined as the token.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
If you want a Daily Reboot script - take a look at roomdevices-macros-samples/Daily Reboot/DailyReboot.js at master · CiscoDevNet/roomdevices-macros-samples · GitHub
Wayne
Matteo Battista
Community Member
Hi mgriff,
I'm attaching:
- a procedure ("configuration_scheduled-reboot.pdf"), written by me, which you can follow;
- also, the n.2 scripts-files(txt);.
Regarding the everyday-reboot, mmmhh...I think:
- you can (spartanly) copy the "reboot" function and paste ut for each day;
- alternatively, you can write a for/while cycle.
Let me know.
Have a Great Day;
Ciao,
Matteo
natalie.bennett
Hi mgriff, I'm wondering why you need the codec rebooted weekly?  I'm exploring to see if anyone is having output issues same as I am.
