05-06-2019 10:54 PM
The Room Kit Mini is successfully registered to Cisco VCS and is able to make calls over WEBGUI. However the Touch 10 is stuck in the welcome page (screenshot attached) as if not registered. Same status after restart/factory reset.
Any insights on the cause of this issue and how to pass this Welcome page ?
05-07-2019 01:25 AM
05-07-2019 05:54 AM
from the web GUI, go to configuration, search on Wizard, and turn off the startup wizard. That should do it.
05-07-2019 06:03 AM
Either run this API command:
xConfiguration UserInterface WebCamOnlyMode: Off
Or upgrade to the latest CE9.7 and it should resolve the issue.
10-01-2022 01:34 AM
Navigate to Settings->configuration
Webcam Mode: OFF (By default AUTO selected)
