Cisco SX-80 keeps reverting back to old IP addresses after restart
WillieDunk59839
Cisco SX-80 keeps reverting back to old IP addresses after restart.
Does anyone know the setting to get it to stop reverting back to old IP addresses?
Anurag Srivastava1
Is there any startup config has been set which is taking place every time once you boot the unit?
Also the network settings are static or DHCP?
If there is nothing like that (or you don't know ) then i will suggest a factory reset and reconfig and see if it resolves the issue.
You can do factory reset from webgui by navigating to Maintenance --> system recovery --> factory reset
Please rate if it is helpful and mark as accepted solution if applicable..
Please rate if it is helpful and mark as accepted solution if applicable....
