04-09-2017 07:31 AM - last edited on 03-25-2019 09:17 PM by ciscomoderator
Hi ,
i have cisco SX20 and CUCM BE6k in site one .
and Cisco SX20 and CME in site two.
if i wnat to make video conferance between site 1 and site 2 , i must have VCS (E,C) or i can connect them direct ?
Solved! Go to Solution.
04-11-2017 09:32 AM
that is correct. I would recommend to configure your sx20 devices to use H323 in Direct mode if you want to use as stand alone. SIP would require a SIP registrar/ SIP proxy server like CUCM or VCS.
To use SX20 as standalone , make sure you have the following configuration using the web interface.
Configuration->Advance Configuration->H323->Profile 1->Callsetup Mode: Direct
04-10-2017 03:26 PM
is site one and site two in the same network/domain? if yes, then you don't need a VCS C/E.
If Site one and site two are in two separate networks then yes, you will need VCS C/E.
04-11-2017 04:43 AM
those two sites will be connect using VPN site-to-site OR MPLS
so i can use SX20 in both site as stand alone and dial the real IP of SX20 ?
04-11-2017 09:32 AM
