Cisco SX20 - Cannot access web interface after factory reset
Hi Guys,
I just did a factory reset on my SX20,
and now I cannot access the web interface, I need to add release key
Basically I cannot set IP addresses directly via the unit administrator
I need to add release key and access any interface
Please help!
Cisco SX20 TC6.3.0
Jens Didriksen
Level 9
Level 9
Can you access the settings locally using the remote control?
If so, you should be able to both enable http as well as set IP address using the remote.
The factory reset should have changed IP setting to DHCP, so if it has a network connection, then this IP address should be shown in the top, left hand corner of the display.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
Perfect, it working now, the switch-port was disable on DHCP.
I can now access it via DHCP and change to the settings.
Thank you very much :)
