05-16-2013 08:41 AM - edited 03-18-2019 01:07 AM
Good afternoon,
What is the standard procedure for recovering a forgotten password on a SX20 Codec?
Thanks in advance,
Luis Neves
05-16-2013 09:26 AM
In such a case, I think one needs to do a factory reset via the power button.
Turn off SX20, then hold the power button for 10 seconds until it starts blinking. Then press the power button twice. SX20 should factory reset and restart automatically.
05-16-2013 10:17 AM
When you hold powe button for 10 sec power led will be off , then press power button again once you find led on then press it 2 times .
http://www.sendspace.com/file/l66qzu
http://www.sendspace.com/file/ay46dx
Please see attached video .
Kind regards,
Dharmmesh
05-28-2013 09:10 PM
Thanks for this Danny.
I would just add an additional comment for the ddts,
CEC fails to bring HDMI1 out of standby when SX20 is reloaded whilst in standby
because if it is active and reloaded, then everything works as expected.
Charles
Lost password go to http://www.recoverlostpassword.com
