Cisco SX20 endpoint with Cisco ISDN Link
albertus1982
Hi Experts,
I have been configuring the SX20 codec connected to ISDN link. My problem is I cannot dial out but can receive calls. My SX20 software version is TC6.3 and my isdn is IL1.1. Hopefully someone can help me with this.
Details:
1 SX20
1 ISDN link
4 ISDN lines
Thank you in advance guys!
Albert
5 Replies 5
Debudas123
I have also same issue, i cant dial out, but incoming calls are coming......
Debabrata
John Regan
We would need some logs to see what is happening, I would advise you open a TAC case but is you can SSH into the ISDN link and ensure the SSH session is being saved to file then here are some commands to get some logging.
NOTE - Ensure SSH session is being captured.
  • Get xstatus and xconfig
  • systemtools calltrace on
         Log context 'BONDING' set to debug level 2
         Log context 'H221' set to debug level 1
         Log context 'H242' set to debug level 1
         Log context 'H320Call' set to debug level 1
         Log context 'H320Crypto' set to debug level 2
         Log context 'ISDNTrace' set to debug level 2
  • log ctx SipPacket debug 9
  • log output on (This will output all the logging to the SSH session terminal session screen)
  • Start/receive call and recreate the problem
  • Disconnect the call, and turn off the logging
  • log output off (Type this in even though the screen is scrolling with output)
  • systemtools calltrace off
    Log context 'BONDING' set to debug level 0
    Log context 'H221' set to debug level 0
    Log context 'H242' set to debug level 0
    Log context 'H320Call' set to debug level 0
    Log context 'H320Crypto' set to debug level 0
    Log context 'ISDNTrace' set to debug level 0
  • log ctx sippacket debug 0
Send the capture text file of the console showing xstat, xconf and  debugging output with good explanation of problem, interface being used,  PBX type, line numbering for ISDN etc.
If you provide the file I can have a look to see what the problem is.
John
Hi John,
Than you for your reply. Here's my log file:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.12.13 17:23:46 =~=~=~=~=~=~=~=~=~=~=~=
login as: admin
Welcome to
Cisco TelePresence ISDN link Release IL1.1.0.247d2f9
SW Release Date: 2013-01-30
OK
systemtools calltrace tra ce on
Enable/disable a suite of log entities that may be useful when
debugging call related problems. Logging is typically sent
to the application log file, but can be enabled for a console by
enabling 'log' output, see separate command for this. Please
notice that enabling log may interfere with real-time
characteristics, and increases the chance of loosing H320
side traffic data.
usage:
calltrace on|off - Enable/disable tracing
ERROR
systemtools calltrace trace on                        on
OK
log output on
OK
1474.04 ISDNTrace   ------
1474.05 ISDNTrace   *T 0002387B 3 NT 02 89 01 01
1474.05 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1474.05 ISDNTrace   ------
1474.05 ISDNTrace   *T 0002387B 3 TE 00 89 01 01
1474.05 ISDNTrace   BRI-3 TE: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1474.05 ISDNTrace   *T 0002387B 3 TE 02 89 01 01
1474.05 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1474.06 ISDNTrace   ------
1474.06 ISDNTrace   *T 0002387C 3 NT 00 89 01 01
1474.06 ISDNTrace   BRI-3 NT: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1474.34 ISDNTrace   ------
1474.35 ISDNTrace   *T 00023899 1 NT 02 89 01 05
1474.35 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1474.35 ISDNTrace   ------
1474.35 ISDNTrace   *T 00023899 1 TE 00 89 01 09
1474.35 ISDNTrace   BRI-1 TE: sapi=0  cr=0 tei=68  RR    nr=4 pf=1
1474.35 ISDNTrace   *T 00023899 1 TE 02 89 01 09
1474.35 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1474.36 ISDNTrace   ------
1474.36 ISDNTrace   *T 0002389A 1 NT 00 89 01 05
1474.36 ISDNTrace   BRI-1 NT: sapi=0  cr=0 tei=68  RR    nr=2 pf=1
1483.26 ISDNTrace   ------
1483.26 ISDNTrace   *T 00023C14 2 TE 00 89 01 07
1483.26 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  RR    nr=3 pf=1
1483.26 ISDNTrace   *T 00023C14 2 NT 02 89 01 07
1483.26 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=3 pf=1
1483.26 ISDNTrace   *T 00023C14 2 TE 02 89 01 07
1483.27 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=3 pf=1
1483.27 ISDNTrace   ------
1483.27 ISDNTrace   *T 00023C15 2 NT 00 89 01 07
1483.27 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=3 pf=1
1483.99 ISDNTrace   ------
1483.99 ISDNTrace   *T 00023C5D 4 TE 00 8B 01 01
1483.99 ISDNTrace   BRI-4 TE: sapi=0  cr=0 tei=69  RR    nr=0 pf=1
1484.00 ISDNTrace   *T 00023C5E 4 NT 02 8B 01 01
1484.00 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1484.00 ISDNTrace   ------
1484.00 ISDNTrace   *T 00023C5E 4 TE 02 8B 01 01
1484.00 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1484.00 ISDNTrace   *T 00023C5E 4 NT 00 8B 01 01
1484.00 ISDNTrace   BRI-4 NT: sapi=0  cr=0 tei=69  RR    nr=0 pf=1
1484.06 ISDNTrace   ------
1484.06 ISDNTrace   *T 00023C64 3 NT 02 89 01 01
1484.06 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1484.06 ISDNTrace   *T 00023C64 3 TE 00 89 01 01
1484.06 ISDNTrace   BRI-3 TE: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1484.07 ISDNTrace   ------
1484.07 ISDNTrace   *T 00023C65 3 TE 02 89 01 01
1484.07 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1484.07 ISDNTrace   *T 00023C65 3 NT 00 89 01 01
1484.07 ISDNTrace   BRI-3 NT: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1484.36 ISDNTrace   ------
1484.36 ISDNTrace   *T 00023C82 1 TE 00 89 01 09
1484.36 ISDNTrace   BRI-1 TE: sapi=0  cr=0 tei=68  RR    nr=4 pf=1
1484.36 ISDNTrace   *T 00023C82 1 NT 02 89 01 05
1484.36 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1484.37 ISDNTrace   ------
1484.37 ISDNTrace   *T 00023C83 1 TE 02 89 01 09
1484.37 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1484.37 ISDNTrace   *T 00023C83 1 NT 00 89 01 05
1484.37 ISDNTrace   BRI-1 NT: sapi=0  cr=0 tei=68  RR    nr=2 pf=1
1493.26 ISDNTrace   ------
1493.26 ISDNTrace   *T 00023FFC 2 NT 02 89 01 07
1493.26 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=3 pf=1
1493.26 ISDNTrace   *T 00023FFC 2 TE 02 89 01 07
1493.27 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=3 pf=1
1493.73 ISDNTrace   ------
1493.73 ISDNTrace   *T 0002402B 2 NT 02 FF 03 08 01 01 05 A1 04 03 80 90 A3 18 01 8A 6C 02 00 83 70 05 80 37 32 34 37
1493.73 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=127 UI    pf=0
1493.73 ISDNTrace           pd=8  (Q.931) cref=1 (f=0)
1493.73 ISDNTrace           SETUP
1493.73 ISDNTrace           Sending complete
1493.73 ISDNTrace           Bearer cap: 80 90 a3
1493.73 ISDNTrace               ITU-T, Speech, 64k circuit
1493.74 ISDNTrace               G.711 A-law
1493.74 ISDNTrace           Channel id: 8a
1493.74 ISDNTrace               Exclusive, not D-ch., B2 channel
1493.74 ISDNTrace           Clin numbr: 00 83
1493.74 ISDNTrace               Number type   : Unknown
1493.74 ISDNTrace               Number plan   : Unknown
1493.74 ISDNTrace               Present. ind. : Presentation allowed
1493.74 ISDNTrace               Screening ind : Network provided
1493.74 ISDNTrace           Cled numbr: 80 37 32 34 37
1493.74 ISDNTrace               Called number : 7247
1493.74 H320Call   h320_call_handler::handleH320SACallInd - callId 1
1493.74 H320Call   h320_call::outgoingAltertInd(p=1,s=1) [fe80::c267:afff:fe58:afdc];x-h320tlph=true
1493.75 SipCall I: ==== makeOutgoingCall appId=2, stackId=na
1493.78 SipCall I: sip_call_handler::handleSIPMRtpLocalCapsetInd(2/-1/-1, capsetentries: 3): Received local capset with payload types set
1493.79 H320Call   h320_call_handler::handleH320SAParticipantIdReq(p=1, s=1) Remote requested Participant Id
1493.79 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 0, audioId 0, h221Individ 0
1493.79 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 1, audioId 65535, h221Individ 0
1493.79 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=1, s=1) Incoming media addresses: Type 2, audioId 65535, h221Individ 0
1493.81 ISDNTrace   ------
1493.81 ISDNTrace   *T 00024033 2 TE 00 89 06 06 08 01 81 01
1493.81 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  I     ns=3 nr=3 pf=0
1493.81 ISDNTrace           pd=8  (Q.931) cref=1 (f=1)
1493.81 ISDNTrace           ALERTING
1493.82 ISDNTrace   ------
1493.82 ISDNTrace   *T 00024034 2 NT 00 89 01 08
1493.82 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=4 pf=0
1493.87 SipCall I: sip_call_handler::SIPM_Alert_Ind (2/0/-1)
1493.99 ISDNTrace   ------
1494.00 ISDNTrace   *T 00024045 4 NT 02 8B 01 01
1494.00 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1494.00 ISDNTrace   ------
1494.00 ISDNTrace   *T 00024046 4 TE 02 8B 01 01
1494.00 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1494.08 ISDNTrace   ------
1494.08 ISDNTrace   *T 0002404E 3 TE 00 89 01 01
1494.08 ISDNTrace   BRI-3 TE: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1494.08 ISDNTrace   *T 0002404E 3 NT 02 89 01 01
1494.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1494.08 ISDNTrace   *T 0002404E 3 TE 02 89 01 01
1494.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1494.09 ISDNTrace   ------
1494.09 ISDNTrace   *T 0002404F 3 NT 00 89 01 01
1494.09 ISDNTrace   BRI-3 NT: sapi=0  cr=0 tei=68  RR    nr=0 pf=1
1494.36 ISDNTrace   ------
1494.36 ISDNTrace   *T 0002406A 1 NT 02 89 01 05
1494.36 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1494.36 ISDNTrace   *T 0002406A 1 TE 02 89 01 09
1494.36 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1495.50 SipCall I: sip_call_handler::log_call_cnf(na/0/-1): Incoming callrate=0
1495.50 SipCall I: sip_call_handler::handleSIPMCallCnf(2/0/-1): Call confirmed (ACK received, remoteName: [fe80, remoteURI: sip:[fe80::c267:afff:fe58:afdc];x-h320tlph=true, received_302_301: 0)
1495.51 SipCall I: Setting remote abilities
1495.51 SipCall I: ==== affirmOutgoingCall appId=2, stackId=0, eventCookie=-1
1495.52 H320Call   h320_call::acceptIncomingCall(p=1,s=1) local=h320:7247;x-h320tlph=true  callrate=64000
1495.52 H320Call   h320_call::acceptIncomingCall AppId set 1
1495.52 ISDNTrace   ------
1495.52 ISDNTrace   *T 000240DE 2 TE 00 89 08 06 08 01 81 07
1495.52 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  I     ns=4 nr=3 pf=0
1495.52 ISDNTrace           pd=8  (Q.931) cref=1 (f=1)
1495.53 ISDNTrace           CONNECT
1495.54 ISDNTrace   ------
1495.54 ISDNTrace   *T 000240E0 2 NT 00 89 01 0A
1495.54 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=5 pf=0
1495.55 ISDNTrace   ------
1495.55 ISDNTrace   *T 000240E1 2 NT 02 89 06 0A 08 01 01 0F 18 01 8A
1495.55 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  I     ns=3 nr=5 pf=0
1495.55 ISDNTrace           pd=8  (Q.931) cref=1 (f=0)
1495.55 ISDNTrace           CONNECT ACKNOWLEDGE
1495.55 ISDNTrace           Channel id: 8a
1495.55 ISDNTrace               Exclusive, not D-ch., B2 channel
1495.55 H320Call   h320_call_handler::handleH320SARemoteRateInd callid 1
1495.55 H320Call   h320_call_handler::handleH320SALocalCapsetReq callid 1
1495.56 H320Call   h320_call_handler::handleH320SARemoteCapsetInd callid 1
1495.56 H320Call   h320_call_handler::handleH320SAOutModeEncrReport callid 1
1495.56 H320Call   h320_call_handler::handleH320SACallResAck - stackId 1 channelMap 0x2
1495.57 H320Call   h320_call::signalLocalReceiveCapsetChange(p=1,s=1)
1495.57 RTP I: validateNewSSRC(sid=0) registering new ssrc (ea6c14c4)
1495.57 SipCall I: ==== makeOutgoingUpdate appId=2, stackId=0, eventCookie=-1, isEmptyCap=0, holdState=0
1495.58 SipCall I: sip_call_handler::handleSIPMRtpLocalCapsetInd(2/0/-1, capsetentries: 3): Received local capset with payload types set
1495.58 H320Call   h320_call_handler::handleH320SAOutModeEncrReport callid 1
1495.59 ISDNTrace   ------
1495.59 ISDNTrace   *T 000240E5 2 TE 02 89 01 08
1495.59 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=0
1495.61 H320Call   h320_call_handler::handleH320SAOutModeEncrReport callid 1
1495.61 SipCall I: ==== signalOutgoingModeChange appId=2, stackId=0, eventCookie=-1, isEmptyCap=0, holdState=0
1495.73 SipCall I: sip_call_handler::handleSIPMUpdateCnf (2/0/-1)
1495.73 SipCall I: Setting remote abilities
1501.25 ISDNTrace   ------
1501.25 ISDNTrace   *T 0002431B 2 NT 02 89 08 0A 08 01 01 45 08 02 82 90 1C 16 91 A1 13 02 02 91 83 02 01 22 30 0A A1 05 30 03 02 01 00 82 01 01
1501.25 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  I     ns=4 nr=5 pf=0
1501.25 ISDNTrace           pd=8  (Q.931) cref=1 (f=0)
1501.25 ISDNTrace           DISCONNECT
1501.25 ISDNTrace           Cause:  82 90
1501.25 ISDNTrace               ITU-T Q.931, Local public network
1501.25 ISDNTrace               Normal clearing (16)
1501.25 ISDNTrace           Facility:   91 a1 13 02 02 91 83 02 01 22 30 0a a1 05 30 03 02 01 00 82 01 01
1501.26 H320Call   h320_call_handler::handleH320SADiscInd(p=1, s=1) Received disconnect indication
1501.26 SipCall I: ==== outgoingDisconnect appId=2, stackId=0, eventCookie=-1, (sipCause.dc=8, sipCause.status=0)
1501.26 H320Call   h320_call::affirmIncomingDisconnect(p=1,s=1)
1501.27 SipCall I: sip_call_handler::handleSIPMDiscCnf(2/0/-1): Disconnect confirm
1501.27 ISDNTrace   ------
1501.27 ISDNTrace   *T 0002431D 2 TE 02 89 01 0A
1501.27 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=5 pf=0
1501.28 ISDNTrace   ------
1501.28 ISDNTrace   *T 0002431E 2 TE 00 89 0A 0A 08 01 81 4D
1501.28 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  I     ns=5 nr=5 pf=0
1501.28 ISDNTrace           pd=8  (Q.931) cref=1 (f=1)
1501.28 ISDNTrace           RELEASE
1501.29 ISDNTrace   ------
1501.29 ISDNTrace   *T 0002431F 2 NT 00 89 01 0C
1501.29 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=6 pf=0
1501.31 ISDNTrace   ------
1501.31 ISDNTrace   *T 00024321 2 NT 02 89 0A 0C 08 01 01 5A
1501.31 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  I     ns=5 nr=6 pf=0
1501.31 ISDNTrace           pd=8  (Q.931) cref=1 (f=0)
1501.31 ISDNTrace           RELEASE COMPLETE
1501.31 ISDNTrace   *T 00024321 2 TE 02 89 01 0C
1501.31 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=0
1503.99 ISDNTrace   ------
1503.99 ISDNTrace   *T 0002442D 4 NT 02 8B 01 01
1504.00 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1504.00 ISDNTrace   ------
1504.00 ISDNTrace   *T 0002442E 4 TE 02 8B 01 01
1504.00 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1504.00 ISDNTrace   *T 0002442E 4 TE 00 8B 01 01
1504.00 ISDNTrace   BRI-4 TE: sapi=0  cr=0 tei=69  RR    nr=0 pf=1
1504.01 ISDNTrace   ------
1504.01 ISDNTrace   *T 0002442F 4 NT 00 8B 01 01
1504.01 ISDNTrace   BRI-4 NT: sapi=0  cr=0 tei=69  RR    nr=0 pf=1
1504.08 ISDNTrace   ------
1504.08 ISDNTrace   *T 00024436 3 NT 02 89 01 01
1504.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1504.08 ISDNTrace   *T 00024436 3 TE 02 89 01 01
1504.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1504.36 ISDNTrace   ------
1504.36 ISDNTrace   *T 00024452 1 NT 02 89 01 05
1504.36 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1504.36 ISDNTrace   *T 00024452 1 TE 02 89 01 09
1504.36 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1511.31 ISDNTrace   ------
1511.31 ISDNTrace   *T 00024709 2 NT 02 89 01 0D
1511.31 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1511.31 ISDNTrace   *T 00024709 2 TE 00 89 01 0D
1511.31 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  RR    nr=6 pf=1
1511.32 ISDNTrace   ------
1511.32 ISDNTrace   *T 0002470A 2 TE 02 89 01 0D
1511.32 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1511.32 ISDNTrace   *T 0002470A 2 NT 00 89 01 0D
1511.32 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=6 pf=1
1514.01 ISDNTrace   ------
1514.01 ISDNTrace   *T 00024817 4 NT 02 8B 01 01
1514.01 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1514.01 ISDNTrace   *T 00024817 4 TE 02 8B 01 01
1514.01 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1514.08 ISDNTrace   ------
1514.08 ISDNTrace   *T 0002481E 3 NT 02 89 01 01
1514.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1514.08 ISDNTrace   *T 0002481E 3 TE 02 89 01 01
1514.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1514.36 ISDNTrace   ------
1514.36 ISDNTrace   *T 0002483A 1 NT 02 89 01 05
1514.36 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1514.36 ISDNTrace   *T 0002483A 1 TE 02 89 01 09
1514.36 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1521.33 ISDNTrace   ------
1521.33 ISDNTrace   *T 00024AF3 2 TE 00 89 01 0D
1521.33 ISDNTrace   BRI-2 TE: sapi=0  cr=0 tei=68  RR    nr=6 pf=1
1521.33 ISDNTrace   *T 00024AF3 2 NT 02 89 01 0D
1521.33 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1521.33 ISDNTrace   *T 00024AF3 2 TE 02 89 01 0D
1521.33 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1521.34 ISDNTrace   ------
1521.34 ISDNTrace   *T 00024AF4 2 NT 00 89 01 0D
1521.34 ISDNTrace   BRI-2 NT: sapi=0  cr=0 tei=68  RR    nr=6 pf=1
1524.01 ISDNTrace   ------
1524.01 ISDNTrace   *T 00024BFF 4 NT 02 8B 01 01
1524.01 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1524.01 ISDNTrace   *T 00024BFF 4 TE 02 8B 01 01
1524.01 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1524.08 ISDNTrace   ------
1524.08 ISDNTrace   *T 00024C06 3 NT 02 89 01 01
1524.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1524.08 ISDNTrace   *T 00024C06 3 TE 02 89 01 01
1524.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1524.36 ISDNTrace   ------
1524.36 ISDNTrace   *T 00024C22 1 NT 02 89 01 05
1524.36 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=2 pf=1
1524.36 ISDNTrace   *T 00024C22 1 TE 02 89 01 09
1524.36 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1531.33 ISDNTrace   ------
1531.33 ISDNTrace   *T 00024EDB 2 NT 02 89 01 0D
1531.33 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1531.33 ISDNTrace   *T 00024EDB 2 TE 02 89 01 0D
1531.33 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1531.49 SipStack I: SipUa(ind=65535) SIPUA_handleRecvRequest 3
1531.52 SipCall I: sip_call_handler::log_call_ind(na/0/-1): Incoming callrate=384000 to sip:[fe80::eaed:f3ff:feb5:d406];x-h320number=63254856 from sip:UriWeRegisterToSipFwdWith
1531.52 SipCall I: sip_call::outgoingAlertIndication(): Sending alert indication
1531.53 H320Call   h320_call::makeOutgoingCall(p=2, s=1)
1531.53 H320Call        source=h320:65937246
1531.53 H320Call        destination=h320:63254856
1531.53 H320Call        callrate=384000
1531.54 H320Call   h320_call::makeOutgoingCall stackId 1 calltype: Video, restricted: false
1531.54 H320Call   h320_call_handler::handleH320SAParticipantIdReq(p=2, s=1) Remote requested Participant Id
1531.55 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=2, s=1) Incoming media addresses: Type 0, audioId 0, h221Individ 0
1531.55 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=2, s=1) Incoming media addresses: Type 1, audioId 65535, h221Individ 0
1531.56 H320Call   h320_call_handler::handleH320SAIncMediaAddr(p=2, s=1) Incoming media addresses: Type 2, audioId 65535, h221Individ 0
1531.56 H221   H221I-0 resource
1531.57 H221   H221O-0 resource
1531.57 H221   H221I-0 resource
1531.57 ISDNTrace   ------
1531.57 ISDNTrace   *T 00024EF3 1 TE 00 89 04 08 08 01 02 05 04 02 88 90 6C 09 80 36 35 39 33 37 32 34 36 70 09 80 36 33 32 35 34 38 35 36
1531.57 ISDNTrace   BRI-1 TE: sapi=0  cr=0 tei=68  I     ns=2 nr=4 pf=0
1531.57 ISDNTrace           pd=8  (Q.931) cref=2 (f=0)
1531.57 ISDNTrace           SETUP
1531.57 ISDNTrace           Bearer cap: 88 90
1531.58 ISDNTrace               ITU-T, Unrestricted digital information, 64k circuit
1531.58 ISDNTrace           Clin numbr: 80 36 35 39 33 37 32 34 36
1531.58 ISDNTrace               Number type   : Unknown
1531.58 ISDNTrace               Number plan   : Unknown
1531.58 ISDNTrace               Calling number: 65937246
1531.58 ISDNTrace           Cled numbr: 80 36 33 32 35 34 38 35 36
1531.58 ISDNTrace               Called number : 63254856
1531.60 ISDNTrace   ------
1531.60 ISDNTrace   *T 00024EF6 1 NT 00 89 01 06
1531.60 ISDNTrace   BRI-1 NT: sapi=0  cr=0 tei=68  RR    nr=3 pf=0
1531.63 ISDNTrace   ------
1531.63 ISDNTrace   *T 00024EF9 1 NT 02 89 08 06 08 01 82 0D 18 01 8A
1531.63 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  I     ns=4 nr=3 pf=0
1531.63 ISDNTrace           pd=8  (Q.931) cref=2 (f=1)
1531.63 ISDNTrace           SETUP ACKNOWLEDGE
1531.63 ISDNTrace           Channel id: 8a
1531.63 ISDNTrace               Exclusive, not D-ch., B2 channel
1531.64 ISDNTrace   ------
1531.64 ISDNTrace   *T 00024EFA 1 TE 02 89 01 0A
1531.64 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=5 pf=0
1531.65 ISDNTrace   ------
1531.65 ISDNTrace   *T 00024EFB 1 NT 02 89 0A 06 08 01 82 02
1531.65 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  I     ns=5 nr=3 pf=0
1531.65 ISDNTrace           pd=8  (Q.931) cref=2 (f=1)
1531.65 ISDNTrace           CALL PROCEEDING
1531.65 ISDNTrace   *T 00024EFB 1 TE 02 89 01 0C
1531.65 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=0
1533.65 ISDNTrace   ------
1533.65 ISDNTrace   *T 00024FC3 1 NT 02 89 0C 06 08 01 82 45 08 02 81 D8 1C 16 91 A1 13 02 02 91 84 02 01 22 30 0A A1 05 30 03 02 01 00 82 01 01
1533.65 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  I     ns=6 nr=3 pf=0
1533.65 ISDNTrace           pd=8  (Q.931) cref=2 (f=1)
1533.65 ISDNTrace           DISCONNECT
1533.65 ISDNTrace           Cause:  81 d8
1533.65 ISDNTrace               ITU-T Q.931, Local private network
1533.65 ISDNTrace               Incompatible destination (88)
1533.66 ISDNTrace           Facility:   91 a1 13 02 02 91 84 02 01 22 30 0a a1 05 30 03 02 01 00 82 01 01
1533.66 H320Call   h320_call_handler::handleH320SADiscInd(p=2, s=1) Received disconnect indication
1533.66 SipCall I: ==== rejectIncomingCall appId=na, stackId=0, eventCookie=-1, (sipCause.dc=-1, sipCause.status=0)
1533.66 H320Call   h320_call::affirmIncomingDisconnect(p=2,s=1)
1533.67 ISDNTrace   ------
1533.67 ISDNTrace   *T 00024FC5 1 TE 02 89 01 0E
1533.67 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=7 pf=0
1533.68 ISDNTrace   ------
1533.68 ISDNTrace   *T 00024FC6 1 TE 00 89 06 0E 08 01 02 4D
1533.68 ISDNTrace   BRI-1 TE: sapi=0  cr=0 tei=68  I     ns=3 nr=7 pf=0
1533.68 ISDNTrace           pd=8  (Q.931) cref=2 (f=0)
1533.68 ISDNTrace           RELEASE
1533.69 ISDNTrace   ------
1533.69 ISDNTrace   *T 00024FC7 1 NT 00 89 01 08
1533.69 ISDNTrace   BRI-1 NT: sapi=0  cr=0 tei=68  RR    nr=4 pf=0
1533.71 ISDNTrace   ------
1533.71 ISDNTrace   *T 00024FC9 1 NT 02 89 0E 08 08 01 82 5A
1533.71 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  I     ns=7 nr=4 pf=0
1533.71 ISDNTrace           pd=8  (Q.931) cref=2 (f=1)
1533.71 ISDNTrace           RELEASE COMPLETE
1533.71 ISDNTrace   *T 00024FC9 1 TE 02 89 01 10
1533.71 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=8 pf=0
1534.01 ISDNTrace   ------
1534.01 ISDNTrace   *T 00024FE7 4 NT 02 8B 01 01
1534.01 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1534.01 ISDNTrace   *T 00024FE7 4 TE 02 8B 01 01
1534.01 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1534.08 ISDNTrace   ------
1534.08 ISDNTrace   *T 00024FEE 3 NT 02 89 01 01
1534.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1534.08 ISDNTrace   *T 00024FEE 3 TE 02 89 01 01
1534.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1534.67 H221   H221I-0 resource
1534.67 H221   H221O-0 resource
1541.33 ISDNTrace   ------
1541.33 ISDNTrace   *T 000252C3 2 NT 02 89 01 0D
1541.33 ISDNTrace   BRI-2 NT: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1541.33 ISDNTrace   *T 000252C3 2 TE 02 89 01 0D
1541.33 ISDNTrace   BRI-2 TE: sapi=0  cr=1 tei=68  RR    nr=6 pf=1
1543.71 ISDNTrace   ------
1543.71 ISDNTrace   *T 000253B1 1 NT 02 89 01 09
1543.71 ISDNTrace   BRI-1 NT: sapi=0  cr=1 tei=68  RR    nr=4 pf=1
1543.71 ISDNTrace   *T 000253B1 1 TE 00 89 01 11
1543.71 ISDNTrace   BRI-1 TE: sapi=0  cr=0 tei=68  RR    nr=8 pf=1
1543.72 ISDNTrace   *T 000253B2 1 TE 02 89 01 11
1543.72 ISDNTrace   BRI-1 TE: sapi=0  cr=1 tei=68  RR    nr=8 pf=1
1543.72 ISDNTrace   ------
1543.72 ISDNTrace   *T 000253B2 1 NT 00 89 01 09
1543.72 ISDNTrace   BRI-1 NT: sapi=0  cr=0 tei=68  RR    nr=4 pf=1
1544.01 ISDNTrace   ------
1544.01 ISDNTrace   *T 000253CF 4 NT 02 8B 01 01
1544.01 ISDNTrace   BRI-4 NT: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1544.01 ISDNTrace   *T 000253CF 4 TE 02 8B 01 01
1544.01 ISDNTrace   BRI-4 TE: sapi=0  cr=1 tei=69  RR    nr=0 pf=1
1544.08 ISDNTrace   ------
1544.08 ISDNTrace   *T 000253D6 3 NT 02 89 01 01
1544.08 ISDNTrace   BRI-3 NT: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
1544.08 ISDNTrace   *T 000253D6 3 TE 02 89 01 01
1544.08 ISDNTrace   BRI-3 TE: sapi=0  cr=1 tei=68  RR    nr=0 pf=1
log output off
OK
OK
OK
I am using the ISDN numbers 65937246 up to 49. In the log file, I dialled the 65937247 and can receive the call. But when I dial out 63254856 (polycom's test ISDN number), the call has been disconnected. I am using the 4 BRI interface and put the BRI numbers.
Hopefully you can help me.
Albert
Hi John,
To add more details, I have already raised a ticket on TAC and they have connected to my laptop and check all the config of SX20 and ISDN link. They also told me to get the ISDN line checked. The ISDN service provider managed to get here and checked the lines and told me that the ISDN lines are working properly. We did a test on polycom VC and dialled the polycom test ISDN line, it was successful that we can see the other side. So I think it is not an ISDN issue.
Thank you for your help.
Albert
Hi Albert,
Ok I think I see a couple of problems.
Problem 1:  Incoming calls are setup as a speech circuit not data so that would limit the calls to 64kbps speech.  You need to talk to whoever provides the lines to look at this but for video calls you need data circuits not speech.
On the 1st call which is incoming (initiated by NT which is Network PBX side).
When you place an outgoing call (TE - our side initiates so this is outgoing) you get a digitial line which is correct.
Problem 2:
Outgoing calls fail because the the network responds with:
So it seems the PBX does not like the numbers that are dialled.  Again contact the line provider and check with them, but as this the network side dropping the call there is nothing we can do from our side.
The explanation I found for this error is "This cause indicates an attempt to connect to non-ISDN equipment.                 For example, an analog line.               This cause indicates that the equipment receives a request to                 establish a call that has a low layer compatibility, high layer compatibility,                 or other compatibility attributes (for example, data rate) that the equipment                 cannot accommodate.               This code often appears when the calling device dials the wrong                 number, and reaches a non-ISDN device. Therefore, ensure that you dial the                 correct number.              This cause can also occur when a a data call is made to a voice                 number, or a voice call is made to a number that only supports data. If the                 number is correct, check whether the telco has configured their switch                 incorrectly."
Hope this helps.
John
