Cisco SX80 Codec Integration with CUCM 11.5.1 and VCS 8.10 and WebEX CMR
adusepeney79
We have been provided a document that list he bandwidth utilization for CMR configuration for SX80 which are both registered with CUCM and CVS Control. The VCS Express is controlled by a different management and would like to know the badnwidth utilization before allowing us to configure CMR for our conference rooms equipped with SX80 software version ce 9.3.0 7394032fb9c 2018-03-23.
We have seen bandwidths ranging from 1Mbps to 10Mbps in the document. We also see that we might be able to pull it off with just about as a minimum as 1Mbps.
What is the the recommended rate that the video would suffer and wouldnt be so obvious to the end users? My Firewall engineers are asking if 500-700K would suffice but it seems a bit on the edge to me and not sure how bad the quality would be.
SX80 version ce 9.3.0 7394032fb9c 2018-03-23  registered to  CUCM version 11.5.1 (This might go away due to license)
SX80 version ce 9.3.0 7394032fb9c 2018-03-23 registered to VCS Control version x8.10
VCS-C talks to VCS-E in a DMZ controlled by another group in a different site and is used by many other components.
We are being considerate to other video and audio sessions hosted daily by other components.
Aaron Wilson
Level 5
Level 5
I personally would not go below 1.5M per call. I have done some calls at 1.1M (1152kbps), but its not great, especially with content channel being used.
Aaron Wilson
Level 5
Level 5
Thank you Aaron.
In my subjective experience, 2Mbps is probably the sweet spot for bandwidth/performance trade off. Higher is always better, but I'd avoid going lower if possible.
