Cisco Telepresence and Microsoft Exchange Upgrade
dtom
We are currently running the following software versions:
CallManager - 7.0.2
CTM - 1.6.5
Exchange 2007
The integration with Exchange is used to schedule Telepresence meetings.
Now, the plan is to update Exchange to 2013.  Will this work?  What documentation is available?
Wayne DeNardi
Cisco TelePresence® Management Suite Extension for Microsoft Exchange (Cisco® TMSXE) is the extension for Cisco TelePresence Management Suite (Cisco TMS) that enables telepresence scheduling through Microsoft Outlook.
Microsfot Exchange 2013 is supported in the newer versions of TMSXE (version 3.1 onwards) - the latest being TMSXE4.0.3.
Note: you may need to upgrade your TMS to support the requiredTMSXE version.  TMS version 14.2 or higher is requried for TMSXE3.1, and TMS14.4.2 for the latest TMSXE4.0.3.
As for docuemtnation, I suggest you start with the Release Notes for TMS and TMSXE.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
