01-31-2014 12:13 AM - edited 03-18-2019 02:31 AM
Hi All,
I have telepresence endpoints connected through EDGE provisioning. With provisioning enabled, endpoints are getting address book informations from CUCM. I would like to change the address book link permanently. If I change the link, it is unchanged until next reboot, next reregistration,... If I set the startup script, it will run the script before provisioning setup. Do you have any ideas, how can I accomplish this.
BR,
S.K.
01-31-2014 12:51 AM
Hi Sebastjan,
MXP has separate phonebook and provisioning configurations.
for phonebook:
xconfiguration corporatedirectory mode: on
xconfiguration corporatedirectory address: IP address of CUCM
xconfiguration corporatedirectory path:https://ipaddress:8443/cucm-uds/users
for provisioning:
xconfiguration externalmanager address:
xconfiguration externalmanager path:
please make sure your external manager address is of CUCM.
01-31-2014 01:12 AM
Hi Amit,
Long time no see..
I am refering to EX90 and SX20 endpoints.
Endpoint gets the https://ipaddress:8443/cucm-uds/users configuration. But I would like to set it to custom link. And I can. But after restart the default is configured again. I would like to find a way to make it custom all the time...
01-31-2014 01:35 AM
Hi Sebastjan,
yes long time.
is it also provisioned with CUCM ?
xConfiguration Phonebook Server 1 ID: "default"
*c xConfiguration Phonebook Server 1 Type: CUCM
*c xConfiguration Phonebook Server 1 URL: "https://:8443/cucm-uds/users"
*c xConfiguration Provisioning Mode: CUCM
*c xConfiguration Provisioning ExternalManager Address:
*c xConfiguration Provisioning ExternalManager Protocol: HTTP
*c xConfiguration Provisioning ExternalManager Path: ""
*c xConfiguration Provisioning ExternalManager Domain: ""
*c xConfiguration Provisioning Connectivity: Auto
if this is changing after restart or reboot, this is something related to provisining
try to disable provisioning by xConfiguration Provisioning Mode: off and check if it still changes or not.
01-31-2014 01:48 AM
If provisioning is Off, then the registration fails. So after setting mode to Off, the endpoint unregisters. And then I set it to Edge again, and it is registered, with all settings changed from CUCM. So I need to run Startup Script again, to set all needed settings to required.
Any more clues?
01-31-2014 03:39 AM
yes, provisioning may cause your device to unregister if it is set to off.
however, provisioning and phonebook settings are separate on SX20 and EX90, so even though it is unprovisioned , you should get phonebook.
if after doing a restart, phonebook stay, then we can see why keeping provisioning to on losses phonebook.
just a small test to check
