Cisco TelePresence MX800 speakerTrack
cmalaluan
Beginner
Beginner
Currently our system allow you to connect to others with Zoom account or Point to Point connection.  Is there a software update that allows us to connect to webex meeting on the touch panel?  I don't see icons on the panel for use to use to connect to Zoom, or Teams.  Is it possible ?
what is your current version ? Upgrade to latest version CE9.15 which is supported by MX800, and you  can see the webex icon on the touch panel but for third party conference applications such as zoom, if you are able to dial zoom meetings right now , you can enable the micro and apply xapi script to display Zoom icon with speed dial or entering meeting id
Recognize Your Peers
