Cisco Telepresence Retrieve Serial Number from CUCM
How to retrieve the serial number of all my endpoints (400 endpoints) registered to the CUCM ?
Fird
mbowden7
Serial Grabber will retrieve your serial numbers.  You can download Serialgrabber from http://download.cnet.com/Serial-Grabber/3000-2084_4-10805763.html
 Enter the ip range of your ip phones and search.  It will retrieve several parameters other than serial numbers(switch name, switch port,....
or
Phoneview http://www.unifiedfx.com/phoneview-inventory/
Hope this helps,
please rate
SC_Collab
I was wondering too if there was anyway to view Serial Numbers of Telepresence devices in CUCM
Eric Ingram
Level 4
Level 4
We use python script to look at <IPaddress/status.xml> page and pull relevant data and dump into a SQL database that way we can run it anytime or on intervals.
Hi Eric,
Could you please share the procedure for how to use python script?
