01-03-2018 08:42 PM - edited 03-18-2019 01:44 PM
I have zero exposure to Cisco telepresence but have experience with expressway for MRA and CUCM 8.5-11.5. I need to start supporting below MX devices, can I configure them just like CUCM devices/phones or do I need to spin up a VCS nodes? Or has Expressway taken care of VCS now or do you recommend VCS or Prime for anything else like management/firmware updates?
Cisco MX200
Cisco MX300
Cisco MX700
Cisco MX800
Cisco CP-DX80
Solved! Go to Solution.
01-03-2018 09:58 PM
Those endpoints can all register and be provisioned fine with your CUCM. Make sure you have the relevant device package installed to enable support of those endpoint versions.
Your "Expresssway" devices are effectively the same software as the "VCS", just with a different licence key, and perform the majority of the same functions in your CUCM environment.
01-03-2018 09:58 PM
01-04-2018 08:12 PM
Is Cisco TelePresence Server required for meeting?
01-04-2018 10:52 PM - edited 01-04-2018 10:54 PM
A conference bridge is required for hosting multipoint conferences, unless the endpoints have a Multisite license. Multisite license will allow you to use the embedded conference bridge within the endpoint software, and all endpoints in your list support Multisite, except the DX80. If you require a conference bridge, recommended platform is Cisco Meeting Server and has replaced TelePresence Server which is no longer being sold.
01-15-2018 09:54 PM
Does cisco give trials of Cisco Meeting Server for UCS virtual environment?
