Cisco TMS provisioning problem
David Anstee
Level 4
Level 4
Having an issue with a TMS/VCS installation.
Have followed the provisioning guide and setup provisioning for use with Movi/Jabber.
Using TMS to import users from AD, all appears to work and can see users in the TMS provisioning directory.
However these users do not show in VCS? And logins fail. However if we create a static user from TMS (not AD imported) the user account appears in both TMS and VCS and can login ok from jabber client?
I'm struggling to understand why the imported AD accounts are not replicating to the VCS?
We are using TMS 13.1.2 and VCS x7.0.3
All TMS agent diagnostics run without errors.
Any guidance/assistance is much appreciated
13 Replies 13
Jens Didriksen
Level 9
Level 9
Might pay to take a look at the Authenticating Devices Deployment Guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-0.pdf
Please rate replies and mark question(s) as "answered" if applicable.
At this stage I wasnt looking at 'Authenticating' with LDAP/AD - purely using it to pull User configuration for provisioning.
Magnus Ohm
Hi David
Did you add the VCS to the domain so that the Movi users are logging in with domain\username? There is a process for setting this up. If not please see below:
On a regular basis you can import users from AD to the provisioning directory, but it will never import the AD password and the VCS will not forward the authentication to the AD unless this is setup.
So try to edit one of the imported AD users and change the password for that user, then try to log in with that user just as a test.
The users will never show up in the directory unless they have logged in at least once to get an assigned contact method / device. So when users start to log in they will start to show up in the directory. If you can log in with the manually created user, replication is working and phonebooks is working if this user shows up in the directory.
Hope this helps!
/Magnus
Magnus Ohm
Another thing can be registration issues, i.e if the imported AD users has a "firstname" and not a lastname and the device uri pattern is i.e {firstname}.{lastname}@domain.com. If this is the case the user won't be able to register to the VCS.
Just as a check if my previous post was not of any help.
/Magnus
Hi Magnus,
I am working with David on this issue.
Yes that's very helpful!  Once I changed the password of the AD user from within TMS the user was able to login and authenticate!
The user however still does not appear in VCS control under users?  Is that normal?  Also is it possible to have password authentication backed off to AD?  It seems unusual that the the movi user name can be verified by AD but the password cannot.
Many thanks for your assistance on this!
regards
Gurp
Good!
So are you using findme and for the VCS address (SIP Server address) in the provisioning directory is this a DNS name or ip?
/Magnus
Hey there,  The VCS server is an IP address and yes, we shall be using find me.
thanks
Gurp
What happens if you enable findme and change the ip to the FQDN of the VCS? Do the users populate?
/Magnus Ohm
Hi Magnus,
TMS is configured to communicate to the VCS using Hostname. FindMe is already enabled.
However the users do not appear in the FindMe search in VCS? Even users that have succesfully logged in, still do not appear in VCS?
Only entries that were manually created in TMS appear in the VCS FindMe Search, none of the LDAP/AD imported users?
Any ideas
David
Hi Gurp,
My understanding is that If you are talking about Find me device uri's provisioned through TMS then yes you would be able to see the accounts under users.
Also you can authenticate the MOVI users using the AD password as well. Please refer the document for more details.
Alok
Magnus Ohm
I just have to confirm, but you have set a findme uri pattern in the tms provisioning directory right?
/magnus
Yes in TMS --> Provisioning --> Directory we have configured a Sub-Folder under 'root' and in this Sub Folder are the account imported from AD.
Also we have configured FindMe URI in the format of {username}@domain.com and FindMe Caller ID also the same.Device URI as {username}.{device.model}@domain.com
With the FindMe Templates - are these only applied at 'root' level?
Magnus Ohm
Adding to my last post:
And the findme template is setup in the prov dir?
