02-12-2019 08:18 AM - edited 03-18-2019 02:39 PM
We have losed the virtual machine of BBDD SQL for TMS (15.6.1), the TMS virtual machine is OK.
We are going to deploy a new BBDD and we have to joing with the TMS that is working fine.
Could you please indicate me how to do it?
Thanks for your help,
David Lozano
02-12-2019 08:22 AM
apologies for my ignorance.. could you please let me know what is BBDD?
Shalid
02-12-2019 08:48 AM
Hi Shalid,
Sorry!!
BBDD = Data Base
Thank you,
02-13-2019 06:53 AM
Do you have any back up of the TMS database (TMSNG)? it does not be recent but if you have one it is pretty straight forward. you can start the procedure from step 3 mentioned in the following document - Restore TMS database
Else it is the same as configuring a new database for TMS and you will lose all operational and system configuration data since these are stored in the SQL database.
Database Server Instance: <External SQL Server IP Address> (Note: Installed External SQL Server with default instance name: MSSQLSERVER)
Further configuration details you can find in following URL from page 283. Cisco TMS - DB Connection Settings
I hope it helps you further
Shalid
Please remember to rate helpful responses and identify helpful or correct answers.
