Ideally it should be removed in few mins once you cancelled the meeting.
But if it is not please try t check event logs for TMSXE and TMS to know what exactly happened when you cancelled the meeting.
Please rate if it is helpful and mark as accepted solution if applicable,...
Please rate if it is helpful and mark as accepted solution if applicable....
