02-11-2024 10:55 AM
Dear All
Could someone help me about the correct commant to send to a cisco codec to change the state of a group button and i got always error messages
for example to switch group button with widget ID 1 for button 1 i used the following command
xcommand UserInterface Extensions Widget Action WidgetId:1:1 Type:pressed
I got the error "unknown widget
I Also Tried another
xCommand UserInterface Extensions Widget SetValue Value:pressed WidgetId:widget_1:2
I got the same error
Could someone tell me the correct command ?
regards
I also tried another
Solved! Go to Solution.
02-12-2024 07:17 PM
For all the xAPI commands and their formats, there is a great guide on-line: RoomOS for Collab Devices (cisco.com)
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-12-2024 07:17 PM
02-13-2024 01:15 AM
