cisco UI Group buttons
Pedro Serras
Dear All
Could someone help me about the correct commant to send to a cisco codec to change the state of a group button and i got always error messages
for example to switch group  button with widget ID 1 for button 1 i used the following command
xcommand UserInterface Extensions Widget Action WidgetId:1:1 Type:pressed
I got the error "unknown widget
I Also Tried another
xCommand UserInterface Extensions Widget SetValue Value:pressed WidgetId:widget_1:2
I got the same error
Could someone tell me the correct command ?
regards
I also tried another
Wayne DeNardi
For all the xAPI commands and their formats, there is a great guide on-line: RoomOS for Collab Devices (cisco.com)
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Wayne
Hello Wayne ,
thanks a lot for your email
I have the document and i can detect the buttons that i created; my problem is to send a command to modify the buttons , for example in a group switch of 3 buttons i want to know what is the command that i need to send to cisco codec to switch from button 1 to button 3 ( for example )
I test the following command "xCommand UserInterface Extensions Widget SetValue Value: Value WidgetId:WidgetId" and i got error messages
please let me know if there is other command available to do it
regards
